Does anyone make one?
Discussion in 'The Garage' started by BlazerWheels, Dec 17, 2003.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    I know for the Newer model GM Trucks there are chips to increase performance, mileage, etc. Does anyone make a chip/ECM replacement for an '85??? Just wondering... /forums/images/graemlins/confused.gif
  2. dyeager535
    26,982
    191
    They do, but they are worthless. They typically advance timing, which requires premium fuel, and increase performance only slightly, if at all.
    You'd get a lot more fun out of something like headers, better exhaust, different cam, etc.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Just checked JET and hypertech... I didn't see one. I suspect its due to the carburetor.
    John
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    umm I'd like to see the computer in your 85, aka there shouldn't be one. Hard to put a chip in a computer that isn't there. Hmm I have heard Cali trucks had computers, anyone confirm and what the heck did it do?
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Actually 85's did have a primitive form of computer in them to sense knocks in the motor and decrease timing. Electronic Spark Control or ESC. My 85 had the computer under the dash and the knock sensor on the passengers side of the block. They were carburorated but they DID have a computer. And FYI 86's had a computer controlled carb.
  6. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    [/ QUOTE ] /forums/images/graemlins/thumb.gif
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ESC is an ignition thing my 84 with 305 came with it as well. I eliminated it. Its not really that much of a computer, doesn't control much so no chip for it.
  8. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    85 Blazers and Jimmies in california had ECMs. Carb, distributor and emissions are all controlled by it. Even have a check engine light.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ESt was not just cali thing, it was national thing, it is an engine electronic spark timing control module, looks like a smaller version of TBI ECM
    all since 1980 cept 3/4 ton GVW and mostly 305 engines, but you couldnt get 350 in 1/2 ton for most of the 80s anyways, so..
    this subject is very misunderstood by most ppl
    bottom line is that the system is simply EST, electronic spark timing, it is a basic HEI engine timing system, involves electronic controlled Q jet and HEI and no more than that except a coupel of TVS's and alot of vacuum hoses everywhere all over the engine and a knock sensor and in most cases no vacuum advance and about half with a MAP sensor and O2 sensor,. but not all, look at your emissions label under hood.
  10. dyeager535
    26,982
    191
    And you are one of them.
    If the carb has a mixture control solenoid, please explain how it is not computer controlled? If it's not an ECM, what is it? It certainly doesn't use ESC to control mixture. /forums/images/graemlins/rolleyes.gif
    I've got the '85-86 parts manual scan of the CCC Q-jet used in CA applications if you need to have proof to believe and understand that trucks DID get CCC some years.
