Does anyone own a 208 that DOESN'T leak?!?
Discussion in 'The Garage' started by COCHEV, Sep 17, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Does anyone own a 208 that DOESN\'T leak?!?
    i've replaced both output seals and now it leaks out where the gear sellector bolts on. Grrrrrrr. i love cleaning my undercarage only to have my rear axle, frame and drive shaft covered with a fine film of ATF. /forums/images/graemlins/angryfire.gif
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Re: Does anyone own a 208 that DOESN\'T leak?!?
    hasnt ever leaked a drop... took the driveshaft out for the one ton conversion and I see the rear seal is now dry and brittle... so Ill try a new seal.. I hate leaks so I hope it stays dry in the future,,,
    are you lubricating your seals before installing them,, if you dont then sometimes they "burn" a little then theyll leak for sure... a dab of bearing grease etc works great
    cam
  3. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Don't worry about it, it keeps the rust off and its easier to wash the mud off.
  4. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Mine always leaks, but not enough to really get anyplace. A little through the case halves and a little out the shaft.
    It also occasionally blows out the breather. I have no idea why it does this and nobody anywhere can explain why it might be happening. /forums/images/graemlins/angryfire.gif
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have 2 that dont leak and a 241 that doesn't. Must just be yours! /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  6. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    My don't but thats cuz theres no fluid in it anymore /forums/images/graemlins/rolleyes.gif
  7. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    Mine didn't until the seal between the transmission and the case went out. It overfilled the case, and the seals started leaking. It really didn't take much time or money to drop the case and replace all the seals. And, now, it's back to not leaking again.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    EVERY aluminum case leakes. My friend bought a '99 Dodge Ram 1500 a few years ago with 18,000 miles on it. Guess what? It leaked!!!!!
    I dunno what it is, but I've never seen one that didn't leak. If someone tells you theres doesn't leak, just check out under their rig. It leaks, they just don't know it yet.
  9. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I wonder if this could explain why I'm slinging oil sometimes. Is there any way to tell the seal is bad without taking it all apart?
  10. dyeager535
    26,977
    Pull the *fill* plug. If fluid pours out, and you had it filled correctly before, you know that the seal is bad.
    My 465/205 seal went bad, started "weeping" fluid out of the front and rear outputs...obviously just until the tranny and transfercase fluid levels equalized again, because it's not constant...the fluid in the transmission never drops below a certain level from what I can tell.
  11. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Mine leaks between the case halves behind the torque arm. It's slowly getting worse. I think I'm going to try putting a vacuum to the case and sucking in some sealer next time I get a chance. I'll eventually fix it the right way when I replace the chain.
  12. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    my fords 208 has never leaked in the 8 years we have owned it. but then u ntill now it was just used to pull a trailer and never wheeled so that might be a factor. /forums/images/graemlins/confused.gif
  13. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I wonder if inclines can make this problem better or worse. The last time I had oil out the breather I had been parked on a hill for a while. Maybe the oil slowly drained into the T-case, then was overfull and blew out on the drive home... /forums/images/graemlins/thinking.gif
  14. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    This is a different subject, but what are the symptoms of a loose chain?
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A skipping sound in 4wd.
  16. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    mine does not leak . grease your seals up when u install them .halves bolt together u can get some anorobic sealer im not sure how to spell it anyways Gm sells it it is red in color and does not need air to cure like RTV the servive manual calls for the special sealer for transfer case assembly
    Kevin /forums/images/graemlins/k5.gif
  17. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    A clunking sound in 4low that reminds you of tires rubbing on the front fenders.
    Mine does it when zipping around in sand with the stupid pedal to the floor at high speeds in second gear. It won't do it in 4high or at low speeds in 4low.
    To test it, just find some sand and put her in 4low. Take off moderately hard and if it doesn't clunk repeatedly try a little harder. Eventually you might have to hold 'er in second gear to get 'er to clunk. It usually requires the chain to be floating (spinning fast) for it to slip.
    It needs to have a stout load on it to get it to skip too. I've tried on gravel and couldn't get it to do it either because the truck would just keep accelerating.
  18. chosen1
    chosen1 Registered Member
    Nov 5, 2001
    24
    Cudahy Wisconsin USA
    Yeh, Mine don't leak "yet" on my 84 Jeep J20 Pick up truck. It's got 86,000 miles on it. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  19. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    from what i can tell, mine leaks right out where the shifter bolts on. a good shop told me that there is an o-ring in there but you have to pull the shift arm out of there to replace it and to do that you have to split the case. so then i might as well re seal the whole beeatch /forums/images/graemlins/grin.gif
