Does anyone run a welded diff. or spool on the street??
Discussion in 'The Garage' started by stangfootball34, Oct 23, 2004.
  1. stangfootball34
    stangfootball34 Registered Member
    Aug 21, 2002
    27
    Just wondering how many if any guys out there run spools or welded differentials in there daily driven rigs? And how bad does it really suck?
  2. mrk5
    Apr 20, 2004
    12,341
    1,046
    Northern Colorado
    I've been thinking about a mini spool in my 12b. There's a lot of reading if you do a search. This has been debated several times.
    But, I'm also interested in hearing some new opinions on this topic.
  3. stangfootball34
    Aug 21, 2002
    27
    Ya I know there is quit a bit on this topic but I was looking to steer it more in a way of can you weld it up with the limited slip crap in there or can you just take it out and then weld it up I really have no clue /forums/images/graemlins/dunno.gif
  4. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Don't know about the limeted slip,but I ran my '73 p-up welded front and back for years without a problem.I also wasn't driving much on the street,just chirped the tires around corners,got peoples attention... /forums/images/graemlins/usaflag.gif
  5. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I did it and its annoying as all hell. Noticably makes the truck work harder unless your going in a perfect straight line which seldom happens.
  6. ronnny3
    ronnny3 Registered Member
    Oct 5, 2004
    10
    georgia
    was it still or did it have the 44/12 bolt axles and what size tires? /forums/images/graemlins/thinking.gif
  7. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I used mine as a daily driver for several months w/ a welded 14bolt... its not that bad. It definetly chirps the tires ALOT... you can't pull into the gas station or a parking spot w/o getting a few looks. It is a little harder on tires than a standard locker, but not that much. I recently took out my welded 14blt and put in a welded D70. NO biggie.
  8. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    i found it was noticably harder on tires than a Detroit...and a lot more annoying. I ran a welded 14 with 36" TSL's for two years on the street. The Detroit makes the truck a lot more civilized...
    Rene
  9. nomo4x4
    nomo4x4 Guest
    I ran a welded 10 bolt with 3.73's and 31" tires and blew it up 3 times as a daily driver...Which is why I need another rear end right now...I'd recomend against it! It really sucks in parking lots, a lot of frame twist and binding issues when the tires have traction (pavement) if it were on dirt or soft ground then it's fine, because the inside tire can spin around a turn, but if it can't spin on a tight corner, its just going to break over and over like mine. Good luck.
    Zak
  10. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I welded my 14 bolt a few months ago and I'm waiting to install my 5.13 gears before I can run it. I'll have 44" TSL's and an SM465 so I'm sure the binding issue will be there. I don't really care though, I had a detroit with 36's and an automatic and it chirped the tires around corners most of the time anyways. I had the old school detroit though, not one of these newer "soft lockers" /forums/images/graemlins/dunno.gif
  11. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I rarely run mine on the street unless its to the trail but yes it makes noise and wears the tires.
