Does anyone use a gasket?
Discussion in 'The Garage' started by BozoWise, May 13, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    What do you guys use on your diff covers? Should I get a gasket or just use RTV on them (44 and 14 FF) If I use RTV which kind should I use? Should I put it on the cover and the diff, etc. etc,
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I use RTV and a gasket, makes it easy to remove the debris from the cover and diff when you take it back off. I put a very thin coat of Permatex Ultra black on both sides of the gasket.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I use nothing but RTV. I've found the gasket's (in my case) alway's leak!! Not anymore though...
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    They leak with a gasket and RTV? That's wild, I wonder why? The only thing I can think of is the cover is bent? Just curious dude.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I always try to use a good quality gasket without anything else. As many times as we have to go into these things, that makes it easier if you can get it to seal. Both my front and back axles are like this now and they do not leak. I've been into that front about 4, maybe 5 times since I put the new gasket on. As long as the cover's have not been over torqued, a good gasket will do the trick. If I ever have problems with the raw gasket sealing, I'll use Permatex Black with a gasket like Fred suggested.
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Clean both surfaces and RTV.
  7. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Just put my axles together with Ultra Black RTV... and the darn things BOTH leaked by the time I put 1500 miles on them! /forums/images/icons/frown.gif So now I've gotten gaskets from Napa, and new 3m sealant to try out... I REALLY hope this seals them, I've lost over $80 in perfectly good oil... /forums/images/icons/mad.gif so this had better solve the problem!
    -Dan
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    I guess I just depends on your luck /forums/images/icons/smile.gif
  9. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    My brother just got his rear end rebuilt and he asked if they used a gasket because it wasnt on the bill and they just used RTV.
  10. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If the cover is dimpled in at the bolt holes then take the ball end of a ball pein hammer center it over the hole and tap it with another hammer.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    BTW, my earlier post is talking about dedicated (or majority use) trail rigs that are "gone into" frequently. It was meant as a sort of contrast to the normal “glue everything” approach, but I guess I was not clear. Seems like some people misunderstood that I was suggesting not using sealer on "normal" duty rigs. That's not what I meant, I’m talking about different applications. If I pop the lid on my Ram, it will get a gasket with Super Black. That would be a case where I would expect to button it up and (hopefully) never go in again. My K30 is not that way. Seems like I'm in it every other week end so far between cleaning the water contamination out (2 times in), putting the locker in, and then the seals. God I hope that’s the end of it, at least till I do 5.13s or something breaks...
  12. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I've used the cork gaskets, they have never leaked and I hate goofing around with the messy sealant if I dont have to anyway. I'm putting my 12 bolt in soon, the stock cover was rusted badly and I cant seem to find a nice factory steel one (the salvage yard i go to will not sell diff covers as well as oil pans and tranny pans, any ideas on why?, I cant figure it out) so I ordered a chrome one. Do I need to use any special sealer to make the chrome seal?
  13. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I always use blue or black Permatex with no gasket. I have never had a leak. If your covers are straight and in good condition, you will not have any leaks.
  14. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Clean surfaces and red Permatex on the cover(s). No leaks. Might be the the only place on my truck that doesn't leak /forums/images/icons/laugh.gif!!!!!
    John
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    gaskets and no sealant here.
    I may put a few drops of weatherstrip adhesive to hold the gasket to the cover to make it easier to bolt on.
    I hate scrapping up all the silli putty that people goop on for no reason.
    it seems to glog the filter on the solvent tank
  16. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I agree with m j. I only use gaskets (unless I don't have one and RTV is ALL I have, might be the case for people on the trail). Alot depends on the condition of the cover and the housing. Housings rarely warp, but if a good rock were to hit it, it could chunk/deform/indent/etc., and if the cover is warped/damaged/etc. a gasket may not work. A gasket is only made to take up so much tolerance. RTV can be gobbed to take up the extra tolerance, but I prefer to get a good cover or fix the existing one. I hate the paper-thin chrome covers, but the one on my front 10 bolt on the 78 was one of those. The Previous Owner put on a layer of RTV, gasket, another layer of RTV, a second gasket, and then a third layer of RTV to get it to seal and cranked the snot out of the bolts. It didn't leak but was way overkill, not to mention a PITA to clean and I hate scraping/cleaning RTV/Silicone. The cover was warped to $hit around the bolt holes (frickin thin chrome covers). I tried to find my old stock cover (couldn't find it from my 80), so I spent 15-20 min. fixing the old cover (soft jawed vice/ and rubber mallet). I made it so the area around the bolt holes were actually a little further away from the face of the pumpkin (as opposed to flush stock, or pulled in after over cranking the bolts). I used one stock gasket from NAPA, cleaned both surfaces well with a die-grinder (with a Scotch-Brite pad) and then washed with brake cleaner. Installed gasket, bolts, tightening in a criss-cross pattern, and no leaks what so-ever. If I had a chip in the face of the pumpkin or cover, then I would probably use RTV, but only in that area.
    Sometimes I use a dab to hold the gasket in place, but usually I will use a small dab of wheel bearing grease to do the same thing.
    This is just my experience with cover gaskets. You can use RTV, but use only as much as necessary. It's not a good idea to glob it as it can get caught in bearings or oiling passages (motor, tranny, axles, t-cases, etc.). To each his own, and whatever works 4 U. /forums/images/icons/smile.gif
  17. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    a question for RTV users... whatdya to on the trail if you need to get in the diff to check things out? I mean... that RTV stuff has to cure before you use it right? If so, when you put the cover back on.. on trail... how well would that work? seems like if RTV was the cool way to go... it might pay to have a cheap spare gasket in the spare parts box just in case....
    J
  18. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The RTV does have a stated cure time, but every time (about every two months) that I have changed my gear oil, I just run a bead around the cover and bolt holes and put the cover back on. Then I fill it w/ oil and drive it around to get all the parts lubed up. I don't think it has ever set longer than a 1/2 hour from installation to driving, w/ no leaks.
    John
  19. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I found it is easier to remove the cover if you use a gasket and like ultra black. I had mine serviced and they only used RTV on it and the damn thing was a real PITA to get off after that, it certainly was sealed well though. Cover was no longer straight after removal however.
