does flipping your air cleaner lid actually work?
Discussion in 'The Garage' started by Topdown, Jun 21, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... so I have read that flipping your lid works, but I want to hear it from folks that have done it. Is it just a TBI thing? Fuel injected benefit?
    Thanks in advance.
    -Ryan
  2. Can Can
    15,516
    54
    Cochrane, Alberta, Canada
    Are you referring to flipping the air cleaner lid upside down to create an open element air cleaner?
    If so, keep in mind that doing so will allow your engine to suck in warm air from the engine compartment. You're better off making sure that cooler air reaches the intake.
    The only thing that I know it accomplishes for sure is that it makes your engine sound a little louder....... /forums/images/graemlins/smirk.gif
  3. tRustyK5
    Jul 23, 2000
    35,119
    160
    E-town baby!
    Hillbilly horsepower...it's louder, it must be faster/forums/images/graemlins/rolleyes.gif
    A cooler intake charge is better for power...but you can't hear it with the ducting in place.
    Rene
  4. Topdown
    Nov 26, 2002
    2,598
    heheh... like fart-can mufflers - Damn, thats the fastest Honda I have ever heard.
  5. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,124
    8
    Phoenix AZ
    I've done it to my own TBI and carbureted vehicles, either the flipping method or replacing the lid with a smaller diameter one. I know the air entering the filter will be hotter, but I have noticed (seat of the pants style) a nice increase in power/slightly longer powerband on all of the vehicles I have done it to. The cooler air theory is definitely a valid one, but so many of the factory "cold air ducts" are undersized, pick up air from a less than desireable area, or have a restriction in them. Sometimes the restriction is for noise reduction, but I will take the noise increase for the power increase any day. Hey, if nothing else, try it--if you don't like it, flip it back over (as free of a mod as you can get /forums/images/graemlins/thumb.gif). Every vehicle will like something different, mine like it, yours may not.
    Just my $.02. Have Fun!
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Thanks in advance.
    -Ryan
    Sometimea it does. A friend of mine had a '69 Camero that the seconderies wouldn't open on the Q-jet, fliped the air cleaner top and they opened fine. On his it wouldn't pull enough air thru the snorkel. /forums/images/graemlins/thumb.gif
  7. dyeager535
    26,237
    38
    Flowtest your air intake system, and compare that to the CFM your throttle body is *capable* of flowing.
    Either that, or dyno test both combinations.
    Not a clear cut answer, seat of the pants dyno doesn't cut it. Hotter air=less power, but also too little air=less power.
    I speculate that when you throw in whatever temp differences there are, and figure in any intake restriction, you will see very little difference between maximum engine airflow requirements and maximum air intake CFM numbers.
    Of course inlet design is very important, us later guys have a much larger air intake, stock, than the earlier trucks.
    I've flipped the air cleaner lid, noticed no MPG difference which indicates there is no efficiency lost there.
    Anyone got any calculations for CFM for air through a pipe? I can go measure the stock later plastic tube for diameter if so. Some variables that can't be accounted for easily, ribbed pipe, change from round to rectangle, etc., but might give us an idea.
  8. mosesburb
    Apr 20, 2003
    2,124
    8
    Phoenix AZ
    I still think it is easier/cheaper to flip the lid and see if it runs better. Why build a clock if all you want to know is what time it is??
