Does frame decide year?
Discussion in 'The Garage' started by dysphemism, Dec 27, 2002.
  1. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    Does the frame of your truck decide what year it is considered? Like a 73 frame with a 2003 body would be smog exempt, etc?
  2. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    not in Alabama...2003 on a '73 frame is considered a 2003
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Some states have a Street Rod loop hole. If like the vehicle is 20 years or older and has gone through frame or body changes, you can register it as a street rod and get away with most anything. the guy from Maryland that had an s10 Blazer body on his full size frame was street legal with big fat tires and no mudflaps or emissions anywhere. Might not apply in your case though.
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    You will be using the VIN from the 2003 cab to register the vehicle.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Here in Kans-Ass, its the body VIN that determines the year.
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    louisiana its the vin also.
    nathan
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm guessing you care about CA.
    In CA it is the frame but you have to jump through some hoops to get it regestered.
  8. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Offroad Unlimited just built a way tricked out 2001 Suburban Prerunner on a '73 frame to get past this same issue. They are in Burbank, Ca. This should get ya to the article.
    Preruuner 'Burb
  9. dysphemism
    Oct 26, 2001
    667
    Fremont, CA
    awesome man thanks.
