Does installing the shackle flip do away with...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Feb 12, 2004.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    the blocks? Installed the Rancho 4" lift with 2" blocks in the rear. Installing a flip, what, does away with the blocks? Any other benefits? And opinions as to the best flip to buy. Thanks!
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The most common flip (ORD style) will give 4" of lift. That would be too much for you set up with the 4" springs (now a total of 8"). I would reccomend the ORD 2.5" lift flip kit. That would let you remove the 2" block and keep your 4" springs. Or you can go to a 4" flip and use the 2" block with stock springs. There are more options but those are the ones I am most familiar with.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You have a 4" spring up front and 2" block in the rear? That would look like a major saggy butt problem! Yes a 4" shackle flip will eliminate the blocks in the rear. Most of the free/cheap ways to do it will give you about 4-5".
  4. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    He probably has 2" AAL and 2" blocks in the back. So he would need to remove the AAL also or else he'll end up with 6" of lift.
