does it make a difference??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tacoma, Feb 7, 2006.
  1. tacoma
    tacoma 1/2 ton status
    Jan 14, 2005
    317
    tooele UT
    Thinking about helping out my 87 TBI 454, starting first w/air, then working my way into the motor. So here's the question:
    Compared to the funky first-year cobbled together TBI intake w/the funky coolant-heated TBI spacer (what the hell is that for, anyway), is the Edelbrock TBI intake an improvement or not?
    Comparing the two visually it appears the the Edelbrock has a better set of runners on it, taller and straighter shot (slightly) than the factory model. For $250, I hope it helps improve SOMETHING.
    SO: anyone install one? and what happened.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    good 4 barrel intake with adapter plate flows much better than tbi intake. and ditch the heated adaptor. then i would also get ajustuble fuel pressure unit. thay say adding 2-3 lbs over stock setting is good also.
