does it matter.....
Discussion in 'The Garage' started by jmeti000, Sep 1, 2005.
  1. jmeti000
    jmeti000 Registered Member
    Jul 13, 2005
    33
    texas
    i had a 31 gallon tank with a hole...so obviously i needed a new one. went to every yard in town and the only blazer around happens to have a 25 gallon tank. will that cause any sort of running problems...other than having to fill up the tank more???
    thanks
    me :bow:
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Only thing i can think of is that your fuel-pickup will be too long for the smaller tank. Other than the depth of tank I believe they are the same. I got a new 25 gallon tank for $25 + shipping.....I'm tring to find the link right now. :D
  3. Stomper
    May 11, 2002
    3,767
    Iowa
    Found it......Link
  4. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I've done this swap I swappedthe fuel pickup too. The only other thing I had to change was the filler hose it was bigger on the 25 gal. but if you're in there you should swap it any way :D
  5. diesel4me
    Jul 24, 2003
    17,540
    935
    Massachussetts
    go new...
    I'd get a new tank,unless you luck out,and find a recently replaced one in a junkyard..they cost about 130 bucks in my area..maybe less if I shop around..it will save you the hassle of the sending unit not reading right,etc..I never have much luck with used tanks-most are as rusted as mine were in junkyard trucks,and most of them get crushed or dented from them picking it up with a forkloader.. :crazy:
  6. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    The reason the one on the 25 was bigger was 'cuz Coleman's has the military ones, which have a larger filltube. It's intended for a CUCV.
    And yes, the sender is specific for 31's and 25's, and the straps are shorter for the smaller tank.
    I went the other way recently on my CUCV, which had the 25 from the factory... but enough room under the skidplate for a 31.
    I got a civvy 31, so I had to fudge the fillter tube, plus the longer sender and longer straps.
    -- A
  7. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    mine wasn't from colemans
  8. dyeager535
    26,977
    Tank straps will be different as well.
