does it swap? fuel tank suburban to blazer
Discussion in '1973-1991 K5 | Suburban | Truck' started by drftsub, Jan 31, 2007.
  1. drftsub
    drftsub Registered Member
    Feb 20, 2006
    11
    nor cal
    Hey all, wondering if anyone knows if the fuel tank will swap between suburban / blazer.
    thanks!
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,161
    Sacramento, CA
    The suburban tank will not fit in a blazer.
    It will fit in a long bed truck in place of the spare tire.
    :D
  3. dyeager535
    26,454
    59
    I thought the small suburban tank (31 gallons) was the same as a Blazer 31 gallon tank, and the 40 gallon Sub unit wouldn't fit?
    Somewhere here (search) I believe someone measured the various tanks.
  4. imiceman44
    Aug 5, 2002
    15,161
    Sacramento, CA
    I didn't know they offered the 31 gal tank in the sub.
    I have the 40 gal, and it won't fit.
    The 45 gallon from my van won't fit in either the sub or the blazer, it's wider than the frame in those trucks. :o
  5. fixmy59bug
    fixmy59bug Registered Member
    Feb 28, 2006
    88
    Riverside, Ca
    Unfortunately they did. That is what I am stuck with in my 89 GMC suburban. Is it possible to upgrade to the 40 gallon tank in my 'Burban?
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,146
    Hollywierd, CA
    I would think it would be just swapping tanks & straps on the Burb.
    I read the difference between the 25 and 31 in the Blazer is only 2":eek1:
    28 x 28 x 10.5 and 28 x 28 x 12.5.
  7. imiceman44
    Aug 5, 2002
    15,161
    Sacramento, CA
    Yeah, you can even get the 44gal from a diesel sub, that is the biggest you can fit in the sub.
  8. fixmy59bug
    Feb 28, 2006
    88
    Riverside, Ca
    OOOooooohhhhhh. 44 gallons... Now that sounds like a good time. Would I need to upgrade my sender when I upgrade to either tank from my 35 gallon tank? Or will my stock sender unit accurately show my fuel level?
  9. BKinzey
    Jan 13, 2006
    3,146
    Hollywierd, CA
    I only know they are different between gas & diesel. Don't know if your 35 will register correctly in a 44.
    Could be fun though!
    "Hey! Buggy, the needle's on EMPTY!"
    "Screw it! I'm driving the 100 miles to town!"
    Or:
    To friends
    "Geeze guys, I'd drive but the tank is on "E" !"
    :haha::haha:
  10. dyeager535
    26,454
    59
    I can't answer if it will work or not, but depth is the only critical thing when talking similar sending units. All operate/measure the same way, if the depth of the tank is the same, the senders will interchange. (with the normal exceptions like TBI, emissions, etc)
  11. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    What are the measurements of the suburban tanks?
  12. imiceman44
    Aug 5, 2002
    15,161
    Sacramento, CA
    When I get some time I will measure it for you.
    It won't be today but maybe omorrow. :D
