Does JB WELD really work?
Discussion in 'The Garage' started by uglychevyZZ4, Mar 24, 2003.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    never tried it, and need a cheap fix since my burb blew up to get the k5 on the road fast.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've used it a few times and it does work pretty good. Had to use a grinder to get it off.
    Pig Putty works good too.
  3. BowtieGuy3
    BowtieGuy3 Guest
    I also have used it a few times... Works great for little things like a small crack in an intake, etc. I imagine its uses are endless.
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    cool, i need to fix a pinhole in the blazer radiator ( not one of my brighter moments ) to get it going since the burban engine is now toast /forums/images/graemlins/grin.gif will it work for that?
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Can't you just swap radiators ???? Put the good one from the burb into the K5 for the time being ???
  6. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    It should work for that. I used Magnum Steel it fix a pin hole in my radiator. /forums/images/graemlins/thumb.gif
  7. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    nah, sounds like a pain, besides, it is a tad too small, it is a 2 row, 383 needs the fat 3 row /forums/images/graemlins/wink.gif it was a thought though for sure. /forums/images/graemlins/grin.gif
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    You got a rebel flag under your name and you never used JBweld? /forums/images/graemlins/eek.gif It works good and Im guessing it will work but just let it dry good and dont you the fast trying JBweld /forums/images/graemlins/thumb.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    In that case, do it right and soder your 3 row radiator. It's not that hard to do.
  10. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    It kept my truck going for about 5 months after my t-case threw the chain and nearly knocked a chunk out of the case. I cleaned it good with some laquer thinner and used the Kwik stuff, and it does dry quick. It held fine till I swapped it out with the 205. I also used it on my intake after I stripped out the carb bolts.
  11. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    I used it on and old datsoon truck I had the thing kept blowing the headgasket out at the end of #4 cyl.There was a real low spot I just bilt it up and set over night and ground it down and touched it up with a file and drove the s**t out of it and was still going when I sold it(to buy my blazer) /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif mike
  12. mirage
    mirage Registered Member
    Apr 1, 2002
    37
    Mesa, Az
    I was driving an old ford of a friends one day, and some idiot owner before had taken out the distributor and dropped the gear down into the pan. Anyway, while bombin out in the woods the crank picked it up somehow (likely it bounced and the crank just pushed it) and knocked a hole in the side of the block the size of a silver dollar. Anyway, cleaned it up and JB welded it, he's never had a problem with it since! JB Weld rocks! I've also used it for all sorts of other projects and haven't had a problem with the Kwick either. /forums/images/graemlins/smirk.gif
  13. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    versa chem and permatex both make a sealant/puddy/apoxy just for radiators.
    depending on where the problem area is you can use silver solder (powder)and bars leak(liquid)in the radiator.
    -Jeremy
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    A friend' dad ran over a screwdriver a year or so ago and it punched a hole in hi aluminum rim, which was discontinued...payed me $20 and I JB Welded it up and sent it back, no problems so far
  15. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    I poked a hole through a gastank once. I dropped the tank, JB Welded the hole and repainted the tank and never had a problem again! /forums/images/graemlins/thumb.gif I swear by the stuff!
  16. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    ... my burb blew up...
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif What happened to the burb???
    Give me a call if you need a hand.
  17. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    goober, see other thread in garage /forums/images/graemlins/crazy.gif
  18. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Rebuilt Duece 'n halfs (M35A3s) also known as Extended service Program (ESP), use JB Weld to hold the air collar on the axles. The air collar supplies air for the CTIS (Central Tire Inflation system). /forums/images/graemlins/wink.gif
    Chock full of useless information /forums/images/graemlins/thumb.gif
  19. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    I've had both success and failure with JB weld. most of the failures were in high stress area's where there were several directions of shear and torque applied to the seam. other then that, after some of the stuff we fixed on my friends stupid BMW, I'm pretty sure the JB stands for `Junk Bimmer Weld'
    -Rich
  20. 77k5bogger
    77k5bogger Registered Member
    Feb 3, 2003
    40
    Winneconne Wisconsin
    I used the permetex stuff on my radiator and it works really good. Jb weld is awesome, always have a tube in my truck! /forums/images/graemlins/thumb.gif
