Does lift = bad when it comes to towing? Yes??
Discussion in 'Tow & Trailer' started by Yohinan, Apr 22, 2004.
  1. Yohinan
    Yohinan 1/2 ton status
    May 21, 2003
    103
    San Diego
    I am looking into purchasing a tow rig, something along the lines of a 2001/2002 or later Chevy 2500 HD. What I am wondering is should I stay away from lifting my truck at all if I want to tow some heavy weights with it, ie 35' boat trailer, 30' flatbed trailer etc...? If I am ok with lifting it what is the max lift and tire size I can go with before I start running into trouble? I am thinking I should stay away from the lift altogether and use another truck as my toy. Am I overreacting here or just being smart by useing the old brain? What are your suggestions and recommendations? Thanks again for the help. John
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I tow a 28' travel trailer with my burb and it has 6" lift. I don't have any problems with it /forums/images/graemlins/thumb.gif
  3. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    FWIW, I tow a 30 ft. gooseneck which weighs 12-13K lbs. with my crew cab, and it is lifted 4". No noticeable effect on towing performance since the lift.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got a '02 2500 HD Duramax/Allison Crew 4x4 short box. No lift, not even "cranking" the bars, and I run 33" Bridgestone ATs. Taller tires were somewhat for looks (as opposed to the skateboard looking stock tires) but also for improved clearance and footprint since I am sometimes "off road" in it (camp sites, washed out dirt roads, etc.). Honestly, a little lift probably wouldn't hurt much, but it *will* make a difference. How could a higher CoG and more unsprung mass plus leverage against the suspension and brakes not make a difference? The more you lift and bigger the tire, the worse the consequences. If I “get into trouble” towing, I want every advantage I can get. Not worth it to me for an IFS lift. I don't "wheel" my tow rig and lifting it is just a lot more expense and stress on lots of parts (specifically the IFS).
    And honestly, I think most of the IFS lifts look sorta silly anyway. Once in a while you see one that gets moderate use, but 99% of them are pure posers. All that money to make something weaker, slower, drives worse, less comfortable, and add more maintenance… Compromises for function that matters more to a person is one thing, but giving up that much for looks I simply never understood. Just my opinion.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Agreed.... /forums/images/graemlins/grin.gif
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I totally agree with Baddog.
    And this is just my opinion as well. I don't like the stock size tire that comes with my truck, so when they wear, I may try the next size up (285s) or something.
    But as for lifting, I just think it's stupid to do on a tow rig. Not only are you raising the COG and putting more stress than needed on some parts, but you're hurting on fuel economy as well.
    Again, just my personal opinion.
    Boss
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Me too, actually my friend went as far as to lower his for more stability.
    /forums/images/graemlins/whistling.gif
  8. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    raising a cog effects braking alot more than you think. transfer of weight decreases available stopping ability
  9. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I personally love the racing pickups- They are not really lifted, but the have super duper travel. /forums/images/graemlins/smile.gif
  10. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Agreed.
    I have a 4" lift on my daily driver/tow rig. I do like it but it is the last tow rig or daily driver I will lift.
    Wear and tear has increased, gas milage has decreased, hauling stability has decreased so on and so forth.
    Save the lift kits and overly large tires for the rig behind the tow rig. They really are more fun on the dedicated four wheeler. Now that I have my buggy I cringe at taking my truck on trails.
    I still do like my lift on my truck though.
  11. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Nice avatar. Looks familiar. /forums/images/graemlins/thumb.gif
  12. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Something else to remember is that if you use a taller tire after the installation of a lift, the wheel will want to "walk" from side-to-side inside the tire more than it would with a shorter tire which equals less stability. I don't use lift blocks on the rear of a tow vehicle. It seems like that when going around turns or curves that the weight of the trailer would put forces on the rear suspension similar to the forces put on a front suspension when turning (NO lift blocks on front leaf sprung vehicles), making it easy to lose a lift block.
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Good points...
  14. namkrow
    namkrow 1/2 ton status
    Apr 25, 2004
    166
    So Cal
    I have an F350 Superduty (regular cab long bed) 4x4 that's only lifted 1" in the rear.
    The front is lifted 4.5" however.
    It tows great and still handles a load in the bed without looking "cali" style.
    -T
  15. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i have a rear shackle flip and that gets squirrly with qa large heavy trailer at about 65mph... /forums/images/graemlins/peace.gif
  16. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    I have a 5" lift on my cummins dodge with 37" tires and haul my 12000 pound enclosed trailer hauling my truggy and it handles and tows better than it did stock.
    but the rear suspension is all airbags so the truck wont even squat an inch.
    a lift wont hurt your towing capabilities but if its not set up for towing meaning it sags in the rear and lightens up the front it will wander and sway all over.
    I had a lift on my superdoodie and towed the same load and it SUCKED the power was good because of all the mods but it towed like crap.
    the dodge is twice the tow rig it was because it is set up correctly /forums/images/graemlins/waytogo.gif
