Does lift kit size + new tire radius= new overall height?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Dec 3, 2000.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    This may sound stupid but I'm trying to figure out if my rig will fit in the garage after I lift it. At present I have no lift and 31" tires. I was thinking a 6" T.C. spring lift w/ 35" tires. So if the new tires are 4" taller (2" more radius) and the advertised lift is 6", am I looking at a 8 inch higher roofline? I'm just trying to see if my logic is correct on this. I like to be able to work on my rig inside during the winter. Thanks.
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    actually the tires only give half the amount and some tires are much smaller than listed 33,s only 32"1/4 etc
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Lift kit (approx) plus loaded radius of new tires. If a 35" tire's true diameter is 34" the loaded radius would probably be closer to 16" because of the weight of the truck.
    New lifts vary quite a bit. Your old springs may also be sagged from age and use. My Jimmy is 6'8" to the top of the roof with a 4" lift and 35" General Grabbers. The tires have a loaded radius of 16". True diameter of 33 3/4".
    Hope that helps.
    Rene
  4. shum1
    Oct 8, 2000
    270
    UTAH
    Ya that helps, looks like I might make it. Thanks.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Re: Does lift kit size new tire radius= new overall height?
    Yeah, it's simple. Just pull the truck partway into the garage to the point where you have the least clearance between the roof and the door. Then mesure that clearance. To figure out the change of clearance, add the height of the lift kit 1/2 the difference in tire size.
    I took off the seal from the top of my garage door frame and mounted it to the garage door instead. This gave me one more inch of clearance and still made a good seal on the door.
    If you're out of room, another option is to air your tires down to about 10psi.
    The funniest thing is when people don't figure this out ahead of time, install the lift in their garage and then can't get the truck out!
    "They tell me that you can make it to work without big tires. I'm still not convinced."
  6. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    Shum1, you are exactly right in your calculations, however, as Rene pointed out, your 31's aren't really 31" and the 35's won't be 35". Also, if you have been following several recent posts on lifts, the numbers are all over the place. A 6 inch lift may not raise the truck 6". Could be more or less. Depends on the tolerance on the new springs, the condition of your old springs, busings, truck weight, even how tight the shackles are, and might even be affected by the sway bar. It's really hard to tell until you get it all in place.
