Does my 700R4 have a shift kit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Nov 19, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Hi all... When I bought my K5 last year, the transmission seems to shift different than I think it should. I'm hoping that there's nothing wrong with it, and that a previous owner has just added a shift kit in. Here's how it drives...
    If I take off real slowly, it stays in first gear for a while before upshifting to second. If I take off fast, it doesn't stay in first as long, but when it shifts into second gear, it is a hard shift. I managed to get $1000 off the seller's price because of it, but now I want to find out that the tranny is okay and will last. Is there any way of finding out if a shift kit has been added without alot of disassembling?
    Gary Graham
    '83 GMC Jimmy w/ '94 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    No you cant reallt tell if it has a kit without removing the pan and valve body but the problems you describe could be a result of an improperly rigged throttle valve cable.By adjusting the cable it will change the shift characteristics so try to adjust it properly first and then maybe pull the pan and check out the internals!
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    If you end up taking it out for repair make sure that you rebuild it for 4x4 specs. I have heard that you do
    not want the shift kit (Corvette parts) because it causes premature wear and early life failure in trucks.
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
