does penetrating fluid stain....
Discussion in 'The Garage' started by 84gmcjimmy, Nov 6, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I went crazy outside and sprayed every bolt on the frame/axles that I could see with MOOVIT penetrating fluid/lubricant. And it isn't the best for sticking to the metal, so some of it drips down on the cement carport ground. Will it stain? I dont want black splotches all over it in the spring. There is also alot of splatter, from where it hit the bolt/nut/etc and hit the ground.
    If it does stain, I guess I'll look into getting some chemicals to get it cleaned in the spring /forums/images/graemlins/eek.gif
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    any kind of oil will seep into concreet, how bad it stains or how hard to get it cleand up depends on what the makeup of your concreet is and what the finish is, like smooth finish, or broom, or salt etched.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Anything liquid that gets into the pores of the cement will stain it including penetrating oil and the grease that it dissolves and splatters onto the cement. If you are concerned about staining the driveway put cardboard underneath till its done dripping /forums/images/graemlins/thumb.gif
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    it has a really smooth finish.
    I have some carboard, so next time i spray I will use that.
    Thats kind of what I thought, since oil seeps in, fluid would too...
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I tried wiping it up, but it already stained. fast stuff.
    What kind of acid/chemical is used to clean cement and stuff like that?
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Brake cleaner should take it up. Its taken out stains in half the concrete arround my house.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    brake cleaner? I have lots of that. I will try that /forums/images/graemlins/woot.gif
