Does someone make an accessory battery bank?
Discussion in 'The Garage' started by CK5, Aug 20, 2004.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    Not sure on how to describe it, I want to relocate my Battery to the rear which isn't a problem because I can simply hook the cable to my remote selonoid, but that selonoid doesn't have any room left. So I was wondering if I could get a bank of terminal hookups that simply will connect with a cable to my remote selonoid? Not sure if I explanied it quite right...
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I understand, only because I want one of these too and haven't asked yet /forums/images/graemlins/dunno.gif
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Look at some of the pics of my passenger side fire wall. Is that what you want? Basically it's a "bus" of 3/8" lugs that come on CUCVs. I run my 2/0 batter cable from the rear up to that bus. Then the alternator and chassis wiring as well as winch leads hook up on the other lugs.
    [Edit]
    Some blury pics
    More here
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thats waht I'm looking for, gonna have to look for one.
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Welp, thats what I want to do, where can a guy get something like that?
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Look for someone parting out a CUCV. They are on all CUCVs including M1008s, M1009s, etc...
  7. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I bought a single pole one from a boat store (West Marine). They probably have multipost also. Boat stores are great for heave duty battery connections but they are not the cheapest place to shop. I have the main fuse block feed and starter wired to it using the side posts on my battery and then the winch runs off the top posts.
    Mike
    link /forums/images/graemlins/thumb.gif
    http://www.westmarine.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10001&storeId=10001&categoryId=119&langId=-1&subdeptNum=118&storeNum=9
  8. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Could you use those single studs for mounting several things too? They come in red and black and different size studs. Should be available about anywhere. I have one in my DD on the frame up by the alternator. I use to electric fans power supply on it. Electric fuel pump, alternator output, Starter and maybe more. Makes wiring really clean. I also have a pair under the dash wired off a relay for accessories rather than tapping into the fuse box. Just a suggestion.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It's really pretty simple. The lugs all go through a bus bar that connects them electrically and can handle lots of current. Probably 3/4" x 0.120 strap. This is set down inside a plastic insulator with fingers that stick up beyond the lugs. The only difficult part is how to protect it from shorting out; that plastic piece. You could easily buy 2 or more of the single poles with the built in guards, then make a bus to go between them out of strap...
  10. ryoken
    Jun 13, 2003
    29,624
    1,379
    Jersey Shore
    not sure if this is what you want...
  11. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    just thinking someing that simple could be fabed up quire easely.
    get a chunk of brass or copper even a home depo. and drill and tap several holes. thread in some brass screws insulate the back of it with rubber, and the ends to atach it ot where ever you want.
    this is what ihav e been planing to do when i relocat dule batts to the rear and run a wintch and new power blocks ect. /forums/images/graemlins/waytogo.gif
  12. poorboy1
    poorboy1 Registered Member
    May 26, 2004
    56
    Newberg,OR
    I didn't read all the posts but I used a battery shuttoff switch to gain more room for cables. Half of them come off the remote solenoid and the rest come off the post on the shut off switch. plus this way when the truck is stored i can shut it off and my batts will be good, not to mention a good anti-theft device.
  13. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
