Does the frame crack on first gen?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Skyetone, Apr 16, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    I just got done fixing ratpack7's frame at the steering box on his.....85? blazer. It was broke in half. We ar going to get it braced too. I seen ORD makes a kit... Does anyone else? Do I really need it for first gen? A few in the garage say no. WHY?
  2. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    uhhh sure does <a target="_blank" href=http://communities.msn.com/68k10/68k10.msnw?action=ShowPhoto&amp;PhotoID=249>http://communities.msn.com/68k10/68k10.msnw?action=ShowPhoto&amp;PhotoID=249</a>
    thats my 68 K10s frame before i fixed it
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    First gens aren't nearly as common as the second gen problem
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Did your truck come w/ the reinforcing plate? Its hard to tell on the pics. My 71 has one on it...I just assumed they all did. If they didn't come on them all than what years?
  5. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    Both my trucks have a reinforcement plate riveted in behind the steering gearbox (inside frame) - maybe that's why...
  6. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Greg72 did a survey on this. Somebody correct me if I'm wrong, but it's my recollection that the reinforcing plate was added in the '71s and '72s.
  7. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    guess I'll have to look and see. What does it look like? where can I get a kit if it doesn't?
  8. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    It's a reinforcing plate inside the frame rail behind the steering gearbox.... The effect is "double" frame thickness...
    JB
  9. MuddyMudSkipper
    MuddyMudSkipper Registered Member
    Mar 7, 2002
    49
    CA
    My 70 has a stock reinforcement plate. I know from experience that the 2nd gen's have a real problem in that area, no problem with my 70 though.
    Jeff
  10. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    I have sheared all of the bolts off that hold the box to the frame on my 72..... lucky for me I was only backing out of the driveway:)
  11. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    I'll have to look. How did you break the 4 bolts on the steering box? Grade 5 at least right?
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The bolts are Grade 8 from the factory and I wouldn't go any lower. The bolts just fatigue over time and break...I had the same thing happen on my 77 ford van...only when 2 of the bolts broke the 3rd one broke off the ear on the box.
  13. ratpack7
    ratpack7 Guest
    I just saw this post you were off by 11 years on my Blazer it's a 74.
  14. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    whatever it's just a pile of [censored] to me /forums/images/icons/laugh.gif
