does the id number supply the date built ?
Discussion in 'The Garage' started by scrappyk5, Oct 9, 2003.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i do not know what year truck my 14bff came out of.
    it was from a 4wd truck but thats all i know.
    i need to replace all the brake parts including the
    wheel cylinders and springs. will the id number
    on the axle help me get these parts ?
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    if ya need 2 replace all that just go disk its like a FREE upgrade
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Look at the ring gear, assuming it's original it will have a date of manufacture stamped on it. That date may be off by a year or so to the model year of the original vehicle but it will give you a good ball park to work with.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    For wheel cylinders all you need to know is 13" or 11" brakes. And, you can change those without taking out all the springs and removing the shoes. /forums/images/graemlins/thumb.gif
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The wheel cylinders are also different pre and post '83 or whatever year they changed the parking brake set-up.
  6. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    well one side is good and all i am going to replace is the pads and the wheel cylinder. but the other side had froze
    up so i am replacing all the guts .
    tomorrow , i will take the number off the axle and off
    the ring gear. and hope it will tell me the year.
    another question ,
    will the rear brake lines on my 10 bolt hook right up to the wheel cylinders on the 14bff ?
  7. heavy4x4
    Aug 28, 2002
    3,270
    Fitting-wise, yes. /forums/images/graemlins/thumb.gif
    Length/bend-wise, not sure. /forums/images/graemlins/smirk.gif I cut, bent, and flared my own when I did the swap. If yours aren't terribly rusted, go ahead and bend them into position.
