Does the Performance Accessories 3" lift require a shifter ext.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deek, Jun 2, 2003.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    Does the Performance Accessories 3\" lift require a shifter ext.
    I have an auto tranny if it helps... I was just about to order the kit then i noticed that they sell the ext. for 30 buck, & didn't know if it was required to install the kit,
    Please help wanting to order tonight
  2. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    Re: Does the Performance Accessories 3\" lift require a shifter ext.
    or does it come with the kit?
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    It came in the kit i got /forums/images/graemlins/thumb.gif
  4. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    I have and 85 K5 and my kit came with one. It was just a metal rod about as big around as a pencil and about three inches long that I welded onto the existing shifter rod.
  5. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    is there anything that it doesn't come with that is required?
  6. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Only thing I had to get additional for mine was some different bolts for the very back mounts. But this is due to interference caused by my trailer hitch platform. If I didn't have that, I am sure that there would have been nothing else I would have needed.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    You'll have to do some custom mods to your fan shroud cause when you lift the body, the motor stays. Some people have just trimmed the lower lip of the shroud to clear the fan, what i did was cut the shroud in half and extended it using a piece of sheet metal...i used a sheet of stainless steel.
  8. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Tex is right, you may need new bolts for the rear-most body mounts. I too had to purchase longer bolts to make it work. Other than that all the necessary parts come with the kit including the shift linkage extension. I haven't welded mine up yet, but it'd help if I had a welder.
