Does this tranny fluid look burnt?*UPDATE*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jul 26, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I'm tryin to figure out what is wrong with the K5. It has a bad vibe through the first 2 gears (700r4) then settles off and runs normal. Some say it is a bad torque converter. But I have no clue.The fluid does smell a bit burnt. What should I do? Comments?
    http://community.webshots.com/photo/37379966/44914692sdUOkW
    The fluid that is in there now is on the left,and new fluid on the right.. /forums/images/icons/smirk.gif
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Re: Does this tranny fluid look burnt?
    Hmm.....Just checked mine...It's kinda in-between those two shades. /forums/images/icons/grin.gif
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Doesn't look burnt. What does it smell like?
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it does look slightly burnt but not to bad
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    That doesnt look too bad.A bad torque converter wont cause vibration.
  6. UseYourBlinker
    Jun 7, 2000
    11,117
    Not anywhere near what the new fluid smells like. Smells kinda like burnt metal or burnt hair. Has a nasty smell. I don't wanna pull the tranny to find out it was something else. I'm /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  7. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    That smell sounds like the friction disks material when it burns off, the vibration in the first two gears would lead me to believe that they are chattering due to wear. Does is slip and rev high or just chatter (vibration). Has your engine temp come up at all lately?
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    Haven't noticed a change in the temp (scared to drive the K5) It doesn't make a noise,just shakes a bit then smoothes out.
  9. UseYourBlinker
    Jun 7, 2000
    11,117
    When starting off the line from a stop. THe engine runs rough I get vibes then smoothes out after 2nd gear. This is /forums/images/icons/confused.gif
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yes it is burnt or wore out.That fluid looks like SH$$. Change it. Do a complete flush. The fluid in a 700r4 should always look like new. If it gete even a little discolored it should be changed. I dont know if that is the vibration problem or not. But running old burnt wore out fluid is the fastest way I know of to wear out a auto tranny. ATF should always look pink and new if you want your tranny to last.
  11. UseYourBlinker
    Jun 7, 2000
    11,117
    .........so what should I do. Try to flush the tranny,put new fluid. Or drop it and take it to a tranny shop?
  12. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    take your rig to a jiffy jube or something like that....most places like that offer a flush of the entire system (tranny,filter,lines,cooler,torque converter).
    This is a little pricy (&amp;80.00+) but i could fix the problem. (i used to work at one so i've done these and it did help)
    Just a suggestion
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I don't know where you got that information. A bad torque converter can and most likely will shake like hell. Especially when it is grenading from the inside out.
  14. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    My advise is to drop the pan and take a look inside. Look for pieces of metal or chunks of band material. A buildup of fine dark grey stuff on the bottom of the pan is normal if you have a lot of miles on it. If there are pieces of metal or little chunks of stuff in there plan on getting a rebuild soon.
    If you want to flush your tranny yourself and save 80 bucks heres how:
    its handy to have a helper to do this.
    Disconnect one of the cooler lines and route it in a bucket.
    Start the engine and pump out the old fluid while adding new fluid to the trans. Dont let it run dry!!! Start /Stop the engine as needed. Always add as much fluid as you pump out.
    When the fluid comes out looking new and clean you are done.
    hook the cooler back up and check the fluid level and add fluid as needed.
    Plan on using 2- 3 gals of fluid.
  15. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Burnt fluid will taste very different from fresh ATF.....
    You should try a teaspoon of each and report back with your findings.
    STRIPPERS ARE PEOPLE TOO.....
  16. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    MMMMM ATF.
  17. UseYourBlinker
    Jun 7, 2000
    11,117
    Well I pulled the tranny pan,and torque converter cover,and found nothing. No pieces of metal,or plastic.I guess I am just fawked... /forums/images/icons/mad.gif
  18. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmm, Well, I wish I could help ya. If you decide to go with a manula set up or somethin, I want your old 700. /forums/images/icons/grin.gif
  19. dyeager535
    26,982
    191
    Since the converter is physically tied to the motor, wouldn't problems ONLY until second gear be rather strange if the converter was at fault?
    I've heard of *noisy* converters, which make noise in neutral or park, because the bearings/thrust washers are worn out, but a 2 gear only vibration doesn't *seem* like a converter problem.
  20. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    I have done the at-home fluid flush, too. It is really easy if you have an extra oil cooler on the tranny with rubber lines. You can just hook up an empty gallon jug with the line going into it so that it is easy to see how much has come out. You can turn off the engine for jug changes. If your fluid isn't too bad, 3 gallons pretty much changes all of it.
    The forward clutch is engaged for gears 1-4. Shifting to 2nd just applies the band. The shift to 3rd releases the band and engages the 3-4 clutch. Overdrive is just reaplication of the band. I can't think of one single part that would shake in 1st and 2nd, but not 3rd and 4th. Maybe the input reaction shell?
    Maybe it's not the tranny. Maybe it's in the driveline or the flexplate to torque converter bolts are loose?
