Does vacuum pump control auto locking hubs??
Discussion in '1982-Present GM Diesel' started by dallassnowman, Oct 22, 2003.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Read something today , made me wonder, cause my pump doesnt work and 2 months ago had a problem with hubs locking in.
    Does the vacuum pump control the hubs?? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
    6.2 diesel, 1982
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Nope. Vacuum pump provides vacuum to operate CC and heater controls. I would also assume that a diesel truck equipped with a TH350 or a TH400 would still have a vacuum modulator.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    6.2 diesel, 1982
    Definitely no
    There is no connection between the axles and the engine, not on those GM's at least.
    The Jeeps at one time had a Vacuum activated center disconnect, but not GM's.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Definitely no
    GM's did, look at the 80's model S10\S10 Blazer 4x4 their frontend was vacuum controlled.
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Definitely no
    Well good thing I said "not those GM's at least"
    /forums/images/graemlins/grin.gif
    I know never to say never, nobody knows everything.
    Plus I don't like to talk about the small GM's /forums/images/graemlins/rotfl.gif
    Full size is where I concentrate my attention.
    /forums/images/graemlins/thumb.gif
  6. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Ok so how hard is it to replace the vacuum pump??
    And how hard to replace the hubs??
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well the vacuum pump is easy, it's like removing a distributor only you don't need to worry about indexing it for timing.
    The hubs is a different question, I can do it blind folded but it's because I have done so many.
    And I suggest you replace it with a manual hub for durability, it's not as convenient but much stronger.
  8. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    The pump is behind the intake manifold. I don't believe its too hard to change.
    Hubs.
    EASY. Take the hex screws off the hub cap, take the lock ring out. Remove hub. Put new hub in. Put lock ring back in. Put new hub cap on. /forums/images/graemlins/thumb.gif
    P.S. Do a search in the main forums. I think they actually have pictures of set by step now!!
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Vacuum pump is easy like said above. Onbolt one bolt, remove clip, pull vacuum pump out. installing in reverse order. May take a few tries to get the gears to line up, but a very simple swap. 15 min max /forums/images/graemlins/thumb.gif
  10. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Cool Thanks everyone /forums/images/graemlins/smile.gif
    Guess I know where my MONEY is goin next /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gif
