does your gas gauge work??
Discussion in 'The Garage' started by copedrake, Jul 9, 2006.
  1. copedrake
    copedrake Registered Member
    Jul 18, 2005
    27
    san jose ca
    On my 85 sierra, it has two tanks and when either one of them are full( all 16 gallons each) the gas gauge only reads 1/2 way. the switch seems to work fine so it isnt getting stuck in between.
    I was going to check the senders, a bit expensive, but since they both seem to have the same problem, i am thinking it is the gauge.
    Ive had many old trucks, and they all seem to have problems with the gauges, especailly when we lift them. simular problems anybody? whats it like to change out the old gauge or put a different one in?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    google "fix-a-gauge"
  3. copedrake
    Jul 18, 2005
    27
    san jose ca
    i just ordered one and we will see how it works, have you ever used it?
  4. readymix
    May 30, 2004
    6,706
    26
    No, but I have replaced the crystals from a donor gauge before.
    Last time I did it I just installed a whole gauge from a 79 into my 87. The color is different but I don't care....
    Be carefull when emoving the two nuts on the back of the gauge.
  5. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    i got a guage and sending unit from jc whitney for like 22 dollars...workes pretty good....
  6. copedrake
    Jul 18, 2005
    27
    san jose ca
    i thought the sending unit was way more, from LMC truck.
    be careful with the nuts as to not drop them in the dash?
  7. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
    mine CONSISTANTLY is full about .5 inch past the full line and half tank is just right of the 1/2 line.
    91 k5
  8. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    mine works but it dances as the gas sloshes around
  9. hank14
    hank14 Registered Member
    May 2, 2005
    15
    Granbury, TX
    When my tank is full, the gauge reads way past full. When it is on 1/4 tank, it is nearly empty. I'm used to it, but would like for it to read more accurately.
    Also, when I'm low on fuel and turn corners or start uphill, it tries to stall and has died a couple of times. I assume the gas tank is not baffled properly, or do you think my fuel pump is malfunctioning?
  10. jimmy'sjimmy
    jimmy'sjimmy 1/2 ton status
    Dec 22, 2001
    130
    Greenwood Village, CO
    mine reads full and works great until it gets to 1/2 then i have to guess:crazy: my method is to turn a corner and goose it, if it putters and almost stalls its time for gas:wink1:
  11. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,195
    361
    Ridgecrest, CA
    I've fixed a few of these, and those cases it was a corrosion thing. Test the resistance between the leads at the guage - it should be a max of 90 ohms and should hold pretty steady. I was able to fix a couple of them by running a new lead from the guage to the tank, grinding/drillling the frame near the tank, running a new ground lead from the tank to the fresh hole, and then sealing (painting) over the new ground attach point.
  12. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    Mine's kind of like that. When I fill it up, it shows full til it gets about 1/2 tank left, then it drops like a rock to empty.
  13. hank14
    May 2, 2005
    15
    Granbury, TX
    I bought and installed the fix-a-gauge fuel and oil pressure gauges today. It was a very easy project, just the usual difficulty getting the instrument cluster off.
    It didn't fix my erroneous fuel reading, though. Maybe it's the fuel tank side (sending unit). I think I'll leave it alone.
  14. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    thats how mine works i drive maybe 200ish miles a week first 4-5 days i lose *maybe* a 1/4 tank the the next 2-3 is drops sooo fast.
