Does your rad "sip" from your overflow tank?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Apr 26, 2002.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Does your rad \"sip\" from your overflow tank?
    This may be dumb, but I've never really thought about it before? When your rad gets overpressurized it will burp air(and coolant) out through the rad cap and into the overflow tank. I know that......../forums/images/icons/tongue.gif
    BUT......
    If your rad is a little low, does the overflow tank act as a reserve? Does the rad cap act as a vacuum and pull coolant back into the rad? If it does, can somebody explain the physics of it to me?
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Re: Does your rad \"sip\" from your overflow tank?
    Yeah it will "sip" from the tank as long as radiator cap is on while the coolant leaks out of the radiator. When coolant leaks out of the radiator it creates a vaccum and the atmospheric pressure in the overflow tank pushes coolant in to take its place.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's just thermodynamics in action. /forums/images/icons/wink.gif When water gets hot, it expands. The expansion creates pressure. Once it exceeds the pressure rating of the cap, it pushes past the cap and into the overflow tube and tank.
    When water cools, it contracts. The contraction creates a vacuum. If you look closely at a radiator cap, you'll see a small silver disc in the center of the rubber seal. The disc acts as a check valve. When the radiator is pressurized, the valve is closed. When a vacuum forms inside the radiator, the valve opens up and coolant gets sucked back from the overflow tank. /forums/images/icons/cool.gif
  4. Can Can
    15,552
    136
    Thanks!!!/forums/images/icons/smile.gif I always wondered why the "silver disc" kinda wiggled around in the cap a bit. Check valve, eh?/forums/images/icons/cool.gif
  5. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I've always wondered how the coolant got back into the rad threw the cap also. Thanks. I didnt know it had a check valve.
  6. Morphgizmo
    Morphgizmo Registered Member
    Apr 3, 2002
    24
    South Texas
    Thanks for the info Harry.
    I've been curious about that myself.
