Doetsch 8403 Shock Installation ???
Discussion in 'The Garage' started by 88Silverado, Nov 29, 2003.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Installing some 8403's on my 4" lifted 88.
    First, they look a little long and was wondering if they will work on stock rear mounts? Do I need to cut the 1" stop bushing off or whats the setup for a stock 10-bolt??
    Second, the bushings that come with the Shocks are for a smaller bolt. Is there a replacement bushing or do I r&r the bushings from the old shocks or do I just get a smaller bolt?? Whats the norm?
    Im doing the Ford Towers in front so im sure the lower bushing are a problem there and just run a smaller bolt up top.
    Any advice??
    Come on, I got all these crazy ideas from you guys so how did you do it /forums/images/graemlins/deal.gif
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Is there a metal sleeve in the bushing? Try taking that out and see what happens.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have 8403s on the front and rear of my truck. I have a 6" lift on mine.
    They fit great on the stock rear upper. On the axle side, I welded the brackets higher so they don't hang so low.
    About the mounting - I used what was in the kit (there are a couple different spacers, etc.) and found what i need to fit. I don't know why another truck would be different.
  4. 88Silverado
    Mar 13, 2003
    2,664
    Thanks...
    There are only the red bushings in the shocks. The metal sleeves that go inside the bushing are for a bolt one size smaller than the stock bolts I removed. I discovered I could press out the old sleeves on the Ranchos and with a little effort and some grease, they will slide into the red poly bushings. /forums/images/graemlins/thumb.gif
