Dogdge Dana vs. Gm Dana
Discussion in 'The Garage' started by Desro, Feb 28, 2004.
  1. Desro
    Desro Newbie
    Sep 12, 2002
    Is it possible to install a front Dana 60 from a '91 Dodge on my '88 k5 ? /forums/images/graemlins/confused.gif
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am gonna shove a '90 dodge D60 into my 79 K5. If it is leaf sprung the answer is yes. There is a yoke change to be made and the spring pad width is a 1/2" off. No biggy. Oh a 3/4 ton and 1 ton GM use 9/16 studs as do 89 and down dodge D60. A leaf sprung Dodge 60 ('90->up) uses 1/2" studs but they should be interchangable with each other.
  3. bgchvy79
    bgchvy79 1/2 ton status
    Jan 3, 2004
    108
    Moore, SC
    Also, I believe both ford and dodge front axles have the pumpkin on the driver's side, so you may need to divorce your tcase
  4. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Nope dodge is still on the passenger side. Uses kinkpins, locking hubs, and from the knouckles out is interchanable with a GM, hubs, bearings, stubs, and all. The brakes bolt up as well. The late '80's and up versions also have non'necked inners (say beefy) /forums/images/graemlins/peace.gif
  5. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    My bad, the older dodges have the pumpkin on the passenger side, while the newer (prolly early 90's and up) have it on the driver's side
  6. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Bingo, we were both right. I just assume not to converse about the newish dodge axle (or jeep for that matter) as soon as they put on drive plats and a center axle diconnect I said no more. Lets not over look the 14" links for the coils. A ball joint 1 ton is a kick in my book as well.
