DOH !!!Computer question,,,,
Discussion in 'The Lounge' started by wasted wages, Aug 24, 2005.
  1. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Yeah,,,looks like I really screwed up,,, :doah: :doah:
    Went to upgrade my Windows 2k Pro to XP Pro last night,, :D
    and instead of overwriting the 2K ,,,I must have installed it in a seperate partition on the hard drive. Now when the computer boots,it asks me which operating system I would like to run 2K or XP.
    The XP looks like safe mode and the 2K seems to work OK except I can't open my outlook express,
    Am I totally screwed ??
    Can you delete an operating system ? ( XP )
  2. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    u can leave it, but deleating a op system? not without screwing sumthin. get all the stuff u want to keep on another drive(or other storage device) the format whole drive and reload. will be way better and a WHOLE lot easier
  3. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    if u were a puter nerd ther is other ways- but since u are asking i take it ure not so wont bother
  4. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    I'd have to agree with Roz...Nothing beats a fresh reformat and install. If you have a CD burner, I'd put everything you want to keep on a disc (or 2 or 3 or 4 :D ).
    Reformat, install the new OS, and put all your stuff from the CD's you made back onto the the hard drive. Wouldnt hurt to run a defrag after you get everything installed.
  5. docgab
    docgab 1/2 ton status Premium Member
    Oct 1, 2002
    1,166
    Medford, OR
    Yup, a fresh format and clean install is great. If that's not how you want to go, I remember one time I installed a different OS and had something similar happen. Under the add/remove programs though I had the option to uninstall the newest OS installation. Have you checked? I don't recall if it was under the new or the old install, but check them both.
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Many new computers come partitioned with a C: drive as the primary and a D: drive as a recovery drive. What drive did you install XP on? If you installed it on the C: drive, but not on the D: drive, then you should be able to go into XP and set up the D: drive as a recovery drive for XP, or install XP on the D: drive as well. Or, maybe you accidently installed XP on the D: drive. If so, you can uninstall it from the D: drive and then go back and do another install but on the C: drive this time. But, I would agree with the others that the cleanest is to save your files on a CD or other media and then re-format the entire hard drive.
  7. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    Go to start bar, then run and type "msconfig", click OK, click on "boot.ini" tab and remove the 2K line from "operating systems section, click ok. On next reboot it should be only the XP version.
