DOh surface rust, need a lil help
Discussion in 'The Garage' started by stoney126, Oct 14, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    hey all found this on the roof last night. Im going to take a DA sander with some 80 grit and finish it with 180 perhaps. Is there a good rattle can primer I could use along with paint. this is a temp fix till I can get it painted .
    Thanks for any help
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    just sand it and maybe put a little ospho on it (a green rust converting chemical) then sand that a little and prime it with some rattle can duplicolor or other quality automotive primer...
  3. dyeager535
    26,980
    80 seems a bit rough for that to me. the metal isn't thick up there, I use whatever I can that JUST takes the paint and rust off in that area. Anywhere I catch surface rust, I hit it with something like 120, then use whatever krylon I've got lying around. (usually semi-flat black) Also just to get me buy until paintjob is next on the list of things to do.
    Nothing you get is going to match worth squat, the important thing is to stop it before it gets too bad.
  4. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    lol ya im no painter so Im not to worried about it blending or even being the same red. Just want to protect the metal
