Doing 57" swap tomorrow-one thing
Discussion in 'The Garage' started by balzackks84, Jun 16, 2003.
  1. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Doing 57\" swap tomorrow-one thing
    I know some of you are tossing in chevy springs from your 52" packs. Which ones are you using, where? Just wondering so tomorrow after I drive it and happens to be too soft I can look here and know which ones to go after.
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Re: Doing 57\" swap tomorrow-one thing
    The 4 leaf F-150's are too soft for the rear of a Blazer. So, I usually mix in some "add-a-leaves" that I make from the old Chevy pack. With a chop saw you can cut them down to size. I'd try to add at least 2 more leaves if it doesn't lift you too high....
    Here's some sizes I typically cut to:
    total length - length in front of hole/length behind hole
    30" - 13" / 17"
    24" - 10" / 14"
    16" - 6" / 10"
    Make sure and add some spring clamps to keep the leaves from "fanning".
    Hope this helps....
    Marv
  3. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Do you find the 4 leaf + overload also too soft?
