doing a suspension lift
Discussion in 'The Garage' started by jace71, Mar 30, 2007.
  1. jace71
    jace71 Registered Member
    Mar 17, 2007
    32
    Georgia
    I'm ordering a 4" suspension lift for my 75 blazer...I'm sure this has been discussed way too many times but I want to make sure that I get the right parts....I'm getting 4 new springs, 4 shocks, ubolts, brake line extensions, steering box brace, and a steering arm. My question is do I need a t-case drop for a 4" kit? Now I just need to identify my axles and gear ratios... I know I've got a 12 bolt rear so I'm guessing a dana 44 front.
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    that sounds about right for the parts. Cant help you with the gears. I wouldnt drop the t-case unless you have a rear driveline vibration.
  3. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i my self would flip the rear and pass on the rear springs.
    next get a can of p.b. blaster and sprey the heck out of every nut and bolt. and still plan on haveing a bit of trouble.
    then look here for axle i.d. info. http://coloradok5.com/axleguide.shtml
  4. jace71
    Mar 17, 2007
    32
    Georgia
    Ah, thanks for the info.....now as far flipping the rear springs, what does that mean?
  5. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Once its all lifted, don't forget to check front D-shaft for bind at full droop.:D
  6. sweetk30
    Nov 1, 2004
    25,538
    538
  7. jace71
    Mar 17, 2007
    32
    Georgia
    Yep thats the steering brace i was talking about! guess I'll look into the shackle flip instead of new springs for the rear! thanks for the great info
  8. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Double-check that your rear springs are good before you decide on the flip. I was going to do a flip, then found out I had a cracked spring.
  9. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    to get a general idea on ur gear ratio without pulln the cover just jack one tire up and turn it two full rounds and count how many times the pinion turns. i.e it the pinion turns just over 3= 3.08s 3 and 3/4s = 3.73 and so on
    got a locker in the rear just turn the tires once
