Doing my lift.. Which shocks?
Discussion in 'The Garage' started by 78Suburban, May 26, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'm going to have 4" TC springs with 1" zero rates, not moving the axle foward as of now. I already bought the springs and zero rates. I'm also going to save up and order Kert's flip with 6" shackles, probably within the next week. My dad was running into town and I told him to order two E5TZ-18183-A ford shock towers. I plan on probably leaving my rear shock mounts alone for a good while, because money is kinda tight right now. With my setup, will I be ok if I use Gabriel G63438 shocks in all four corners? If so, what is the extended and collapsed length of these shocks, because a buddy of mine may have some different brand shocks with similar deminsions.
    also:
    Will I need to extend my bumpstops? Do I need an extended brake line for my rear? I have a 14ff in the rear, and corp 10 in the front. I may get some 30" extended front brake lines from somebody on here, would those be too long?
    thanks,
    James
  2. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
  3. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Is this the part number for the front ford s-duty shock mounts? Sorry to hijack.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    That is the part number for the front ford shock mounts on the f0250's from the 80's.. just like the ones used in the tech writeup. I ordered two for a total of 26 bucks from the stealership today.
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I went with el-cheapo superlift shocks from their scratch-n-dent store on e-bay (13.50/ea). They pretty much suck on the road, but are okay for slow off the road stuff.
  6. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    So nobody has 5" of lift and ford shock towers? I would love to know what shocks you used up front, and how long they are extended and compressed. Also, what kinda shocks can I use with stock shock mounts in the rear /w a shackle flip?
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i love my gabriels. cheap and life time warrentee
  8. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    ill check those shocks for ya tonight
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    I run Rancho RS5000 shocks on each corner and they aren't bad, but I would recomend going with Rancho RS9000 for even better quality.
