dome light is on with headlights on, any ideas ?
Discussion in 'The Garage' started by R72K5, May 23, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    in the 81 i went and replaced bulbs and fuses throughout the truck
    well the dome lamp always worked with door switches and with headlamp switch but the instrument panel lights didnt, so i replaced the headlamp switch and put in a bulb in the courtesy light for floor board passenger side, so it works too now
    but it and the dome lamp now come on with headlights on, but isnt fully bright but is near to fully bright
    any ideas what is causing that ??
    have instrument panel lights though at least, but driving at night with dome and courtesy lamps on isnt all that spectacular,
    thanks for any ideas as to what to check, hmm...
    i am out of ideas and there are no cut wires in the truck cept for radio
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    have you check all the fuses? gm wireing does wierd things when a fuse blows.
    on my 89 s10, the trailer plugin was wired wrong and didn;t know it, when we plugged it in to the trailer, it blew a fuse. then when we turned on the headlights, the dome lights came on. i forget what fuse it was, but we replaced it and they worked like they're suppose to.
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I'm thinkin that your head light switch has gotten dirty and is letting electricity cross over to your dome light circuit, maybe?
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hmmm... interesting,
    would ahve to be courtesy or dome one since the headlights and instrument panel lights do work, so those two latter fuses are good apparently
    but i checked all the fuses
    so hmm..
    however before this new problem and before i replaced the headlamp switch i replaced a burnt fuse i think it was the courtesy one
    thanks
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Have you tried twisting the headlight switch to the left?
    i can turn on my dome lights with my headlight switch, not shure what year this started, but if you turn the switch to the right, it turns on the dome lights.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i messed all around with the headlamp switch knob yes, that started in at least 67, if not before i know for a fact
    the cause/problem is somewhere else i believe
    all works fine with headlights off
    and all was fine with non working dash lights before i swapped headlamp switch out and replaced burnt fuse
    its something real small and stupid i know, just unsure what,
    somehow the dome and courtesy are getting almost full backfeeed(or whatever you want to call it) from something with the headlights on
    hmm
    i guess i could try a third headlamp switch
    i dunno,
    thanks
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Do you have a cig. lighter? May want to unhook and see if that helps. Everytime i blew a fuse, it was realted to the lighter..
    My .02,
    John
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    You have a blown fuse.
    Here's the deal: There are three "dome lights" in a K5. One in the topper, one on the roof and one under the dash. The ones up top are wired to constant hot and get grounded to the chassis through the door switch. The one under the dash is also tied to hot, but through a different fuse. At least one of these fuses also has some other equipment on it. When you blow the fuse, the bulb under the dash is bridging the top bulbs to some other equipment, through which some current flows to ground. Usually the bulb lights up rather dim since it is in series with something else.
    I can't remember which fuse it is that does this, but it seems to me you lose either your parking lights or the dash lights when you have this condition.
  9. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    interesting.
    remebber it is also grounded at you headlight switch, (white wire i think)
    if it was bridgeing inside the switch to a week ground then it could come on too.:crazy::crazy:
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its a pickup not a k5 it has two lights only
    i guess id have to say its the headlamp switch then
    im just gonna have to put in a brand new one instead of trying used oens
    hum
    fuse i put in hasnt blown, its doing fine
    thanks
  11. justhorsinaround
    Sep 16, 2003
    6,798
    You mean I could maybe be right?
    Hold on while I mark my calendar!!! :rotfl:
  12. Blue85
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    The fact that they are both connected together (@ door switch and headlight switch) is the reason this is possible. It's taking away one of the 12V supplies that makes it happen, though.
    You may remember a science experiment from school where you put two light bulbs in series. The one with the lower wattage rating lights up brighter.
