Dome lite no worky
Discussion in 'The Garage' started by jimmyjack, Jun 12, 2002.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    My dome lite crapped out, I replaced the fuse and just pops. Is the dome lite on it's own circuit? Does it share anything else? My dash lights all work and so does everything else. I took my top off awhile back. All I can think is I put a CB antennae on my blazer and tucked the coax under the headliner plastic. I must've pinched the wire. Thanks for the help!!
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    either tweaked the wire- or you may have disconnected it without knowing it- or even loosened it enough to allow it to eventually work its way out.
    Driver's side, front "rail" of the top- behind a little metal cover is a plug- also if you have carpeting, behind the main carpeted panel- where the ashtrays are- there is ANOTHER connection... I believe they have white/orange and a black wire... or at mine does.
    Brandy
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Thanks for the reply Brandy, I forgot about the lite under the ashtray /forums/images/icons/smirk.gif I know for a fact that it's grounded somewhere. I just need to know if it's on its own circuit. I had a blazer manual but the kids used it to build a ramp for their hot wheels, then left it outside for the dogs to have a turn playing with it............What the hell do they think about????? My oldest was with me when I bought the book for a dollar at the swap meet. I told them both....."don't touch this book or you're toast" It was the first thing they trashed!!!!!!! Anyway, back on topic. Does anyone have a diagram?
  4. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    The dome light and the light under the dash are on the same circuit. I thought it was easier to pull new wire instead of trying to track down the existing short.
  5. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I have and 89 diagram, I'll scan since its most likely to be the same in yours, which was what... an 88? Saw your pictures but wasnt sure...
    I can send them as gifs.
  6. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    It's an 83 but I don't how they'd different, ya know. My e mail is LD610@aol.com thanks!
  7. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I think I left a few key words outta that sentence!
  8. TwoCrowsDesign
    Jul 13, 2001
    387
    They're on their way.
