done 3/4 ton swap .. how to hook E-brake stuff?
Discussion in 'The Garage' started by GMC500, Feb 26, 2007.
  1. GMC500
    GMC500 1/2 ton status
    Aug 19, 2005
    203
    Safwa
    hi all
    I've replaced the old 1/2 tons (10bolts front/rear) on my 1986 K15 with 3/4 ton (14bff/10bolt)
    but how can I hook the E-brake cable ?
    is there any way to modify the stock one ?
    or should I pull a complete setup from a 14bff occupied vehicle ?
    thanks
  2. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    343
    Sacramento California
    does the e brake cable press in from the rear or does it bolt on to the 14 bolt
  3. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I'm interested as well. I have my 14 bolt installed but never hooked up the e-brake.
  4. gm500hprat
    gm500hprat 1/2 ton status
    Feb 28, 2005
    196
    anaheim, ca
    When I did mine it had the same hookup as the 12 bolt did.
  5. GMC500
    Aug 19, 2005
    203
    Safwa
    there are two cables coming from the backside of brake drums of the 14bff
  6. GMC500
    Aug 19, 2005
    203
    Safwa
    maybe there are differences b/t years
    my rig is a 1986 GMC k15 with rear 10 bolt
    donor rig is a 1978 GMC Burb
  7. virgilh
    Sep 8, 2004
    343
    does it bolt on or snap in to place? early 14 bolts bolted on later ones snapped in to place if yours snaps in to place reuse the 10 bolt ones if it bolts on i could get you custom ones made
