Done with full convertible conversion (pics)
Discussion in 'The Garage' started by johnathan, Apr 1, 2007.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Well all the body work is done.I used the material from the top to fill un with,and a quart of bondo. Everything is stick welded.I removed the carpet and found the floor and rocker panel gone on the driver-side:eek1: .I used some 2x2 square tubing and two pieces of angle to construct the new rocker.I tied in to the body rail with some angle as well.That really stiffened the back panel.The passenger side was fine so I welded some angle to stock rocker and tied it in to the body supports.I also discovered a bad heater core:mad: !
    Time to start the cage.I've got some DOM 1 3/4 .125 on the way.$$$$$$$:eek1: ,man that stuff is high!
  2. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Also is anyone running a soft top after a full conv. conversion without grafting a pre-75 windshield frame.If so I would like to see some pics.
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    You could do it the sof top doesn't attach like the hard top would. At least thats how my old K line soft top works I dunno about the newer type...
  4. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    You could also go to someone who makes custom boat tops. They can make custom tops that fit anything. My father has had two boats done this way. Thsy make the ribs, top, snaps or channel for attachment, windows etc. They can also make it in sections with weather resistant zippers so you can run with multiple configurations.
  5. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    :rolleyes: Now that's got me thinking.I believe there is a place in town that does custom tops. I like the idea of different configurations.
  6. Craig Artzner
    Craig Artzner 3/4 ton status GMOTM Winner
    Dec 16, 2006
    6,843
    Northeast Ohio
    That looks awesome! I love seeing the newer trucks chopped. GM should never have gone half-top IMO.
  7. Full Tilt
    Full Tilt Registered Member
    Jul 10, 2006
    16
    hanover park illinois
    nice job!looks great
  8. K5Greeality
    K5Greeality Registered Member
    Oct 23, 2006
    15
    Greeality
    Looks great....I am getting ready to graft in a 75 windshield frame onto my 83.
    I like what you did in the rockers. Did this eliminate all body sag?
    Thanks...:D
