done with the axle swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris Demartini, Oct 28, 2000.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Well, not really. I still have to bleed the master cylinder since some air got in it while the rear calipers were being bled. I also still need to somehow remove the u-joint yoke from the 205 so I can get the new 1350 yoke on so I can mount up that $340 [​IMG] 1-ton rear driveshaft I got today. Then, I can re-weld the shock mounts and be done. I hope to be back in the mud soon. Heres pictures
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Thanks! I had to cut quite a bit off the fenders, but I did it to still look good. When the next roll of film is done, i'll post those pictures. Does anyone know what socket I need to remove the nut that holds the rear yoke on the transfer case?</font color=blue>
  4. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    is that a big blue waggan under the diff? it looks like the wagon i have.
    Well as it gose it gose and under it rolls heavey rubber bouncing on a head.
    (hey i'm a poet)
  5. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    Well acording to my milemaker kit the socket in question is a 1 5/16. Hope this helps!!!
    Bigmeats
    Carl...75 Blazer...Manhattan IL
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    BigFAG71,
    It looks good man, I cant wait to do my swap in a few weeks. Do you have any pointers or information I may need to know? If so, I will chat with you online sometime. How much did the brake kit set you back?
    Neil
    My GT is faster than your GT!!!! [​IMG][​IMG]
    Mudzer 1978/91 K5
    <font color=blue>www.mudzer.coloradoK5.com</font color=blue>
  7. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    You need a 1/2" drive 1 5/16" socket. The 3/4" drive socket won't fit into the yoke without grinding it. That axle looks beautiful. I didn't clean my Dana 60 up before I put it in. Wish I had rear disk brakes too.
    CB
  8. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Thanks MudFAG, I hope you are able to make yours half as cool as mine. Expect to make lots of trips to the parts store, I had to. The brake kit was $300 and the calipers were $65 I think. They changed the kit to use GM 3/4 ton front rotors so the stud holes dont need to be machined, so it'll be a while before you can get your hands on one HA HA [​IMG] !!!! You need to get new u-bolts, and I used a die grinder to make the holes in my old plates bigger. The rearend will also raise the back of your truck about 1.5". I just got shorter blocks. I got a hold of the 1 5/16ths socket, and I just put the driveshaft in (in the cold, in the dark). Now I just have to bleed the master and re-weld the shock mounts
    Oh yeah, I have more R/C experience than you, so you're only smashin the boards faster! [​IMG]</font color=blue>
  9. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Looks great! Now I know who to get down here and help me with one in a few months! [​IMG]
    <font color=blue>I don't get stuck, I'm just in the mud when I stop for lunch [​IMG]
    - NJFourWheelers</font color=blue>
