Donor Shaft For Doubler....
Discussion in 'The Garage' started by dhdescender, Jun 26, 2003.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Howdy...
    I'm doing an adaptor plate on my milling machine for dual transfer cases, using a 32spline connection.
    What could possibly be the donor shaft that is cut down to use between the 203 and 205? Are they using Turbo 400 Tailshafts and respline the 203 side? A 32 spline SM465?
    Help! I know you guys have a plethora of information regarding these sort of adaptors!
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Why not use the intermediate shaft from the 203 cut down and resplined? That's what is generally used when a new shaft is not constructed from scratch. You might want to anneal and then re-heat-treat it too. But be careful, some people have reported breaking the cut down shafts, possibly due to bad HT...
  3. dhdescender
    Aug 10, 2002
    628
    I measured my 32 spline shaft from my SM465 @ approx . 1-1/4" Diam
    Can anyone confirm that the 203 intermediate shaft is at least this diameter?
  4. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    Call mosier eng. they will cut down the original 203 shaft for like 80 dollars last I knew. next day service.
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Isn't that the same answer you gave him on POR? :flipoff2:
  7. rodzzilla
    953
    Grinnell, IA
    At least I'm consistant.
    Never know which one he'll check first. /forums/images/graemlins/tongue.gif
    /forums/images/graemlins/grin.gif
