donor vehicle for driveshaft
Discussion in 'The Garage' started by Blue85, Mar 17, 2004.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Please give me suggestions for a driveshaft donor vehicle. I need a decent amount of slip spline with a 1350 yoke at each end.
  2. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    OK, so nobody had any suggestions. I couldn't come up with a vehicle that took something like this, either. I spent hours in junkyards looking at hundreds of driveshafts and finally found something that will work. It is half of a two-piece shaft from a 91 3/4-ton Suburban. Everything is 1350 series. I took the section with the slip splines in it, which is about 24.5" in the center of range of motion. I was looking for something 1/2-3/4" longer, but this will work short term with the seal on the splines removed. Then I will have it lengthened at a driveshaft shop.
    This is for my Blazer with 14-bolt rear and slip-yoke eliminated NP208. Static length for this application is 35.25", in case anyone cares. (Stock driveshaft length is 29")
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Find a 3/4 ton fixed yoke truck with a 1 piece driveshaft.
  4. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Oh boy, why didn't I think of that? /forums/images/graemlins/rolleyes.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah, roll your eyes at me, but that's where mine came from.
  6. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Of course. It's just that what I really needed was make/model/year of some trucks that were 1-ton with fixed output.
    The K5 wheelbase is different from anything 1-ton, so I didn't think I would find a direct bolt-in shaft, but I was looking for a good core that would just need to be retubed/balanced. As it turns out, it was very hard to find for some reason. Also, you can't call junkyards or do web searches for "drive shaft with slip splines and 1350 U-joints". You need make/model/approximate year or you have to hit every yard by foot and search them all over. Around here, there is almost nothing 1-ton in yards.
    Anyway, I found the motherlode of junkyards. 6 big yards all within about 2 miles of each other and within 45 minutes of my house. 4 of them had a semi trailer full of driveshafts. Even with that, it took me 4 hours to find a good core.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    where is that junk yard at? /forums/images/graemlins/thinking.gif
