Donor vehicles for dana 60 front ends?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DukeBoy88, Oct 15, 2002.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I'm currently building a FF 14-bolt to replace my 10-bolt (I had a lock-right that sheared it's stop pins and mangled the rest, and I don't want to spend any more money on it). I want a dana 60 front to match, but I don't know what differences there was through the years. what years and vehicles can I grab one that fits. If shock mounts or spring perches need to be moved, thats fine.
    Great Site, thanks in advance.
    Dave '88 Jimmy K5
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    this has been covered soooo many times.
    K30's...1977 and up
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, what zakk said.../forums/images/graemlins/wink.gif
    Basically, '77 to '86 for K30's and '87 to '91 for V30's. /forums/images/graemlins/wink.gif
  4. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    Look at older 1 ton dodges too they are almost exactly alike.
  5. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Hey thanks, just picked up 60 out of an '88 K30. does the spacer for dual wheels come off to allow you to bolt near the rotors? or is there more to it?
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I always wondered about that but never had the chance to look at it closely, but I think you should be able to.
    I am sure that not everybody can find a single wheel 4x4 one ton to get the axles from so there must be a way.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The hubs need to be modified to get the single wheel trank width. Wagoner machine will do it for about $100 each. </font color>
  8. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Is that the only way? doesn't a single track width piece bolt on where the dual spacer is now? It looks like it might, but I honestly don't know.
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You can replace the hub with a single wheel unit, but they're hard to find and pricey when you do fine them... </font color>
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Just the bare bearing hubs to replace the dually bearing hubs go for around $250 for a pair, on eBay.
  11. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Thanks shaggy, when you say "replace the hub" are you refering to everything from the spindle out, or just the external piece that covers the hub and bolts between the rotor and wheel?
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The peice that houses the bearings, the rotor is attached to it and it slides on to the spindle. </font color>
  13. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    How do I get in touch with wagoner machine? thanks again.
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
