dont do
Discussion in 'The Lounge' started by Roz, Aug 25, 2005.
  1. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    ok so im a noobe, i know that welding produces UV but i had no idea that it was quite the amount to sunburn the crap out of u. lesson learned-dont weld in tank top and shorts :doah:
    no input needed thanx :o :p:
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Cheaper than a tanning bed. :D
  3. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    now if i could learn to weld behind my back........... ;)
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    hehe, I get burnt every single time I go and work on the pipe fencing at the farm...
    Those welding burns hurt far worse than sunburns, and last a looong time... I'm still peeling from the last burn like 2 weeks ago...
    Just way too hot to wear a long sleeve shirt when you are being beat down on by the sun all day long.
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    hahahah yeah i had always heard of this but i had figured it took days to see the effects. but sure enough after only an hour or so of welding, tan lines form hahaha
  6. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    i got burned real bad once. i usually used gas shielded solid wire in the shop, but a few days, i had to work outside the shop under the awning and crane due to the size of the stuff i was doing. anyway, i had to use flux core wire to box in some 14*3*3/8" channel for some stair stringers, four levels to be exact. i worked essentially in the trinity river bottom in the texas summer heat. short sleeves is a must unless you are planing to do lots of welding. let me tell you, after two days, the inside of my right bicep was black. it peeled and hurt like hell for about two weeks. the flux core must put off more UV than solid gas shielded. never been burned like that again. lesson learned.
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I just burned my forearm yesterday... :doah: :D
  8. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    must be the flux cord, thats what i was using. i dont burn easy either but only welded bout 1/2-hr maybe 45min :crazy:
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I never get burned any where except for my face. Such as if im doing a bunch of tack welds and dont feel like flipping down the mask each time. Next day your whole face is swelled up, beat red, and burns like a mofo when you move it.
    I have started using sunscreen when doing that type of welding and it doesnt happen near as bad.
  10. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    i've done the look away, close eyes bit too, but aftet a while my eyes get burned. so i swithed to an autodarkening hood. never going back. burnt eyes feels like someone poured hot sand into your sockets :angry1: :weld: :yikes: . if they are burned bad enough, a doc will scrape the top layer off your glassies, or it will scar and your vision will be blurry. you only got one set and they can't be replaced (at least for now anyway) so take good care of them.
  11. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i dont like the auto dark hoods, good old scan-o-rama for me
    and once you weld every day for a few years even the skin around you eyes doesent get tender anymore (that might be the skin cancer eating me away though:thinking: )
