Dont know what, but somethin is broke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, May 13, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    Noticed this today...friend and i were testing my flex...stuff and flex to be precise...well after this i drove him to work and i myself went onto work and when pulling in...i made a sharp left turn and noticed soemthing....
    it feels like....at first it felt like the rear driverside wheel was dragging...over the course of the evening its developed into a few other possibilities...mabye the front wheels are tryin to spin when i turn...mabye a u joint is broke....diff grese needes changes...posi trac fluid needs changed...
    theories...
    Hubs broke and wont disengage...
    4X4 is still engaged
    rear diff clutches are sticking, needs re-greased...any ideas?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I would think of 2 things. 1. 1 hub didn't disengage. 2. You busted a govlock.
  3. tecton
    Dec 1, 2002
    1,553
    WV
    when i steer left, thing wants to turn right really fast if i left off the wheel...and its steering weird also...
    we got under there and the little rubber hose coming out of the read diff where its latched up under the body there is like grease all over the metal up there...like its been spewing (known of this for sometime)
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    try backing up for about 35 feet, that is if you have autp hubs. if you have manual hubs, or that dotn work, pull the hubs appart, clean and regrease them and replace broken parts if any(but im sure ya knew that) and re install them.
    Grant
  5. tecton
    Dec 1, 2002
    1,553
    WV
    got back from the garage today...they put it on a lift...ujoins are fine...and they think its the hub thats broke and not releasing
    going to swap in manual's anyway, so its no big thing
