Don't look at me like i'm stupid. . . BUT
Discussion in 'The Garage' started by BowtieRed, Aug 1, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Don\'t look at me like i\'m stupid. . . BUT
    as a TEMPORARY VERY VERY TEMPORARY fix of ONROAD use. . . what would happen if for my driveshaft from a 203 going into a 241 i just welded the telescoping part locked at the right length? HYPOTHETICALLY for a day or two.
    just a question.
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Re: Don\'t look at me like i\'m stupid. . . BUT
    first time you compressed/unloaded your suspension *somthing* would have to give, be it the welds, yoke, ujoint etc...
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd see the driveshaft just bending under the weight personally. It wouldn't work, if you could watch it every little bump in your suspension that thing moves.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    241 has a slip yoke....
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    If the tranny has a slip jointm it should work?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh wait I think he is talking abotu cutting off the end and puting the slip yoke on then welding the telescoping shaft. i still wouldn't do that but thats better. Bowtie am I correct?
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    yes- since the 241 has a slip yoke i need a solid shaft, and was wondering what would happen.
    not a good idea- now- anyone know the length of a sm465/241 combo so i can have my shafts made before i do the swap?
  8. Fletch79
    Fletch79 Registered Member
    May 14, 2003
    63
    Southern Wisconsin
    Why not cap the tail shaft and drive on the fronts until you get a real shaft?
  9. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    My thoughts exactly....
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i'm not really sure my 10 bolt is up to it. would that even work in just regular 4x4? or wouldn't it just spin the rear?
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    not safe. Put it on the shelf for a few days and get your driveline reworked by a pro.
    doing 60 MPH on the freeway, the last thing you want letting loose is the driveline. Not sure how long yours is by my old one could have pitchforked me over, if i was unlucky enuff...
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Not an option. I have to get to school. I HAVE to get to school.
  13. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok- i just need the length of the combo, i'll have the shafts made this week.
  14. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    So do you have a 203 or a 241 in there right now? No rear shaft for it? If the front is open drive on the front shaft. If its a 241 get a plug for the output so you don't dump the ATF. Run in 4HI if its a 241 or HI Loc if its a 203. Even cars have some type of slip built into the shaft and look how straight their DLs are.
  15. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i have a 203 in now. shafts are fine. i'm putting in a 241 with a slip yoke and need new shafts because of the slip yoke and different length, i just need some measurements if possible now, that's all.
