Don't somebody make a degree shim with the 1 1/2" offset *DELETED*
Discussion in 'The Garage' started by keith, Nov 11, 2004.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Don\'t somebody make a degree shim with the 1 1/2\" offset *DELETED*
    Post deleted by keith
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Re: Don\'t somebody make a degree shim with the 1 1/2\" offset
    ORD will taper their 0 rates, but he states in this post that they're a little behind and aren't taking orders for them right now. You may want to call and see what the lead time is for them.
  3. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    ORD or AZ Kickin Off Road /forums/images/graemlins/thumb.gif
  4. keith
    1,158
    La Fayette, GA
    ORD said they are atleast 2 weeks behind and taking no custom orders. /forums/images/graemlins/crazy.gif
  5. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Keith, They are $60.00 plus $10.00 shipping. Two day turn time. Let me know how thick your spring pack is so I can supply the right length bolts.
  6. keith
    1,158
    La Fayette, GA
    Well I have the zero rate now and a seperate shim that is 4 Degrees. I have made some drive line changes and need to turn the pinion up some more. I will not need the u bolts. Is the price still the same?
  7. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    I think he means the bolt that goes through the spring pack, not the ubolts.
  8. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Keith, I will make a new 1" thick shim with 6 degree taper and 1.5" offset. This will be bolted into your spring pack and I need to know how thick your spring pack is so I can supply the correct length bolts. If you want a thicker shim made of 1.5" material it would be 90.00 and have the above features.
