door alignment
Discussion in 'The Garage' started by mostwanted, Oct 30, 2006.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    My door don't line up properly. Someone told me that I needed new hinge pins. Anything else I should look into?
  2. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    does ur door sag ?? if it dont it needs to be adjusted on the hinge worn pins and door hings cause doors to sag.
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    New door pins are in the help section of the local auto parts store and they come with bushings. I believe I paid about $8 a pin. I would replace every thing before trying to adjust it.
  4. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I just did mine today. It's easy but take your time and don't rush. I took my door off, If you don't have power stuff I would recomend you do too. Scribe a mark around the DOOR SIDE of the hinge. Then pull out the sawsall and cut the old pins in the middle. It' a good idea to have somone or somthing to hold the door for you. I had the kid next door and some milk crates. Push old pins and bushings out and replace with new. Use some "c" clamps and sockets to remove and install. Reinstall door and adjust. Also, check the home page and go to tech articals. Somone has a write-up on removable doors.
  5. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    Yeah
    If you have power windows locks or anything of that sort dont assume it'll be fun or easey to re-intsall the door after cutten em all off. It's a bitch i know form experiance. Leave the door up there, but still replace the pins.
  6. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    Crap! I forgot about that!!:mad: I I guess I'll have to wait till I swap in non-power doors. I was going to get rid of that stuff so I can run quik removable doors. The old ones have rust anyhow.:doah:
