door and headlight chime
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Jan 2, 2001.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Does anyone know where the door and headlight chime is located. I know it's some where under the dash, but not sure where it is and what it looks like.
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I think its up by the fuse box, not all models have them. Our '81 did but my '82 does not, I wish it did though.
    "An old Blazer never dies, they just... rust away."
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    chime? theres a chime?
    the only chime i hear is the one to put on your seatbelt when i turn on the ignition
    am i missing out on something here hehe
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  4. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    My memory is kinda fuzzy but I thought some models had the chime when your lights were on and you left your keys in the ignition.
  5. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    Thank goodness the guy that bought mine didn't ask for that option. Though for historical purposes, I'd like to know what the RPO code was for that or what option(s) it was grouped with.
    Taz might go more crazy....
    <font color=red>David, '86 K5</font color=red>
  6. dyeager535
    26,979
    I think it depends on year. I've seen the chimes (on GM cars maybe?) that were plugged INTO the fuse panel, just like an accessory. However, I believe the later trucks had them mounted somewhere near the gas pedal. Either bolted to the pedal housing itself, or around the back of the radio somewhere. Personally I made SURE mine works. I habitually forget to turn the headlights off if I go to work when it is dark, but its light when I get there. The chime on mine is plugged into what they call the "convenience center" which contains the horn relay as well. Black plastic board with a bunch of slots in it, which the various accessoryies plug into, like the horn and chime module.
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  7. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I FOUND IT! Hey Mr. Red, the code from 81 is ...option no. 1T63 Headlamp warning buz
    K5:Big, slow, and flys through the snow. [​IMG]
