Door hinge bushings
Discussion in 'The Garage' started by kyser_soze, Oct 2, 2005.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I am replacing my door hinge pins, and was able to remove them and the spring very easily. I have a spring tool so the spring replacement will go as planned, but I am having problems with installing the bushings. The bushings seem like they are too large in diameter and will no even start. Is this normal? Any suggestions?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You did get the old bushings out right?
    Rene
  3. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    I tapped one out with a screwdriver and there are no hanging scraps and the hole is clean. I was going to tap them on with a small mallet. Do they have to be pressed on with a c-clamp?
  4. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    are you using MotorMite kit #38400 (includes 1 pin and 2 sets of different bushings) or #37375?
    you want to use the bushings that arent fluted, splined whatever.
    i had to tap mine in.
  5. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    GM replacement parts.
  6. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    lucky you, Chevy was open when i did em.
    it took 4 parts stores just to find 2 kits.
  7. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I drilled out the hinge and with some hammering got the bushings in. Not sure if thats what your supposed to do or what but it works.
  8. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    The way we do it at work is take a bolt that will fit in the bushing and longer than the bushing, slide a washer over the bolt bigger than the bushing slide the bushing over the bolt then into the hinge take and put a piece of metal tubing over that, that the bushing can go into but not get stuck then a washer bigger than the tubing and a nut tighten the nut and it pulls the bushing in very easily. Taping on those bushings usually ends up with them breaking.
