Door hinge removal Q???
Discussion in 'The Garage' started by avgas, Jun 17, 2005.
  1. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    Ok, How do you remove the upper door hinge??? There is a bolt that comes from the inside of the vehicle that I can't figure out how to remove, there just doesn't seem to be any access to it. Please advise :)
  2. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    Impact hammer thingy and smashem off...... I want video too :D
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    If you reach up under the dash there should be a rubber plug you can pop out. Use an extension with a swivel socket and you can get it out, kind of a pain though. I don't know why GM engineers thought it was a good idea to hide one bolt like this. :surepal:
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its easier if you remove the dashpad and gauge cluster , you have some bulbs in the cluster that could use replacing anyway , right ? Then its just reach in through the dash and get at it :D
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I'll assume you already have the door off. Next remove the metal plate below the steering colum and then the heater duct hidden by it. While lying on the floor looking out you will see the plug mentioned above. An air ratchet and a couple extensions are a big help. On the pasenger side just unscrew the glove box and you'll have plenty of room.
