door hinges
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Apr 3, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    I know there was a post sometime ago about replaces the door hinges but i cant seem to find it.
    can anyone please tell me how to fix my saggin driver side door? thanks
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    New hinges are cheap through GM. The four bolts on the door are easy enough. Some on the post side are bolted in through the inside. You need to sneak in with a socket and a extension from the inside under the dash. If you have AC this is a real pain. Somebody was rebushing these but I prefer to replace so I can get a new spring too.
    Luke
    84 K5
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    They sell the bushing kits at Autozone, etc. It's easier to take off the hinges, remove the old pin and bushings(if anything is left) redrill the holes, press in the new bushings, re-align everything...the whole process is a pain., but it sure makes the doors work better. If money is no object....get the whole enchilada from GM.....too rich for me though. It can be done with one person...if you're stuborn enuff, but 2 would be much easier. I can elaborate more if needed.
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  4. Cavalry
    Oct 1, 2000
    978
    I bought my new hinges for $28 each. Most people wont need to replace all 4 maybe just the drivers upper
    Luke
    84 K5
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    This is the easy way out, but I wonder how much a body shop would charge to do this? I need to do it but it sounds like one of those projects I start and then quit while I'm ahead...I hate messing with the body...already did it once...spent an hour trying to get my POS Taiwan hood flush with the fender and it came out worse than before...
    90K5
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I unbolted the hinges from the doors, removed the hinge pins, ground off the serations, and drilled a small hole through the ends. I then bolted the hinge halfs back to the doors, put the doors in place, and inserted the hinge pins. The upper pins now go in from the bottom, and a small cotter pin holds them in place (through the holes I drilled). The lower pin goes in from the top, and gravity keeps it in place. I put quick connects on the wires for the door speakers. Now I can remove the doors by myself in under 5 minutes.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    Pete
    I think when I get back from Moab I would like to take a look at your hinges, might be a good way to at least save the doors when running Independance. [​IMG]
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  8. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    The only trail I've run sans doors is Kelly Flats. My frame and body flex is bad enough that I'm afraid they may not go back on if I twist it up good with the doors off. I've already learned the importance of keeping the hood latched. It is fun on the street, though.
    Pete
  9. CK5
    May 19, 1999
    21,623
    701
    CO
    Yeah, thats why custom half doors would be sweet that you could change out, best of both worlds.
    Steve
  10. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    I don't think it would be a problem on most truck, especially not pickups, just when the flex is as bad as mine.
    Pete
  11. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    hey pete, could you possibly show a picture of your finished hinge setup? ive been toying with the idea if half doors for the summer, but changing them out would be a b*tch. You may have solved my problem.
    --matt
    <A target="_blank" HREF=http://www.geocities.com/shaggyk5>http://www.geocities.com/shaggyk5</A>
    <font color=red>SIGN MY GUESTBOOK!</font color=red>
  12. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Sounds pretty cool.
    Become one with nature...........Then marinate it
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Pete, have you thought about installing some of those tube steel rocker panel replacements like Grim and Depdog have? That should stiffen the body up quite a bit! I'm thinking about doing that to my '75 because it flexes like crazy when the top is removed. Perhaps when I install the roll cage it will help stiffen the body up as well.
  14. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Sorry, no digital camera/scanner.
    Pete
