Door Jamb Switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scavenger, Nov 4, 2002.
  1. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    About a year ago I bought a new door jamb switch for the drivers side of my 85 Blazer because the original one was pushed in to the off position and would not pop back out when the door was opened, keeping the dome light from coming on. I just found the forgotten new switch, and decided to install it. When I removed the original one, I got it pulled out about an inch from the hole and the wires came off and went inside the door pillar. Does anyone know how I can get at this wire short of firing up the Sawzall. I tried snagging it with a wire but could'nt even locate it....Thanks.
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I have "fished" them through with a stiff bailing wire. You may have to pull it all the way out, from behind the dash, and start from scratch. I would try bending a hook on some stiff wire and feeling for it first....it's gotta be there somewhere.
  3. scavenger
    Mar 31, 2000
    111
    Southern Wisconsin
    Michael,
    Thanks for responding. I did go out and got a stiffer piece of wire and on the second attempt snagged one, then the other. The new one is in and working.....Thanks again
  4. Michael
    1,576
    Sherman, Texas
    /forums/images/graemlins/thumb.gif
