Door lock issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Shawn, Apr 12, 2007.
  1. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    On my 84 K30, my passenger door will lock but it won't unlock. I just replaced the door with another electric door and same problem. Could a relay cause this?
    My drivers door lock won't work at all but I think it needs a new actuator.
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Mine is doing the same thing. I have been trying to figure it out. But nothing so far.
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    spray all the moving parts with some lube, sounds like you might have a sticking latch assembly.
  4. Shawn
    1,753
    5
    5280'
    Its a new passenger door with the same problem though so I don't think its the latch assembly. If you put your hand over the actuator, its not even trying to unlock.
  5. sixpennylizard
    sixpennylizard Registered Member
    Nov 11, 2006
    64
    Lacey, Wa.
    I have the same problem with my driver door lock. The thing works some times and then just stops out of no where. I think I have tracked the problem down to a poorly installed alarm by the P.O. or whats left of it :doah: Could that be the problem with yours? I think there are 2 relays one for locked and one for unlocked. Mine are under the dash near the driver kickpanel.
  6. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    chack the switch then.
