Door Lock Switch need for 90 Blazer
Discussion in 'Parts & Trucks Wanted' started by opfor2, Mar 15, 2005.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Hi Gang,
    I'm in need of a OEM door lock switch for my 90 Blazer. I know LCM sells them, but I really don't want a cheap "made in china" switch. So if anyone has an OEM switch that there willing to part with please e-mail me.
    droth@cwnet.com
    Dan...
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Just my .02 - I was in the same mode of thinking as you until one day I was stuck with buying switches off of the revolving rack at Napa (forget brand, red package). I could not tell any difference between the 2. Same colored plastic on switch, post were made of the same material, cosmetic piece same crappy plastic.
    The Napa part was not cheap.
  3. offroadnut
    offroadnut 1/2 ton status
    Jun 5, 2003
    116
    Indianapolis, Indiana
    I bought one of those switches from LMC and it works great.... same thing I couldn't tell the difference in the switches.
  4. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    So the switch that you got from LMC was just as good as the OEM one ? If thats the case I guess I'll get one. The dealer quoted me $ 45.00 :mad: for one switch. The LMC switch is $ 22.00.:laugh:
    Dan..
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the one at napa, the "help" brand, are i think $10 or 15
  6. offroadnut
    Jun 5, 2003
    116
    I held the two next to each other and they looked the same... I have only had it about 2 months now but I use it several times a day and it works great. I would look at the one at NAPA... it is probably the same switch as well. As easy as they are to replace even if this one only lasts half as long it is a quarter the cost. if you haven't replaced it yet, there is an easy way to get them out. use a thin regular screw driver and slide it in from the side and it will pop the clip for you to remove it. then you can change it and snap the new one back in. takes about 5 min. or less.
